TH-Mini - tapped horn - by Danley Sound Labs |
Page <12345 12> |
| Author | |||
TDA-Audio
Joined: 11 February 2005 Location: Russian Federation Status: Offline Points: 294 |
Posted: 17 June 2009 at 8:19pm |
frequency graf
B&C 12nw100
full Resolutsuion http://tda-audio.users.photofile.ru/photo/tda-audio/182351/128047183.jpg Ciare 12.00sw
full Resolutsuion http://tda-audio.users.photofile.ru/photo/tda-audio/182351/128047194.jpg
![]() Edited by TDA-Audio - 19 June 2009 at 7:25pm |
Jake_Fielder
Joined: 08 October 2007 Status: Offline Points: 4236 |
Posted: 17 June 2009 at 9:02pm |
wow, is the mic calibrated and everything accurate with that graph? if so then thats pretty good! was that 1w i assume?
Ibex
Posted: 17 June 2009 at 9:41pm |
Sorry, in one of my last posts i thought that the B&C 12NW100 and the B&C 12PS100 have the same thiele&small parameter, but i was wrong, so here you have the correct comparison of the Ciare and the B&C simulated:
black = B&C 12NW100 grey = Ciare 12.00 SW |
Ibex
Posted: 17 June 2009 at 9:47pm |
Yes jake, this would be interesting, cause the simulation shows much lower sensitivity. Seems that the peaky response as shown in the simulation isn't so dramatic in the real world! I'm very glad about this fact! |
TDA-Audio
Posted: 17 June 2009 at 10:12pm |
sensitivity approximately... |
TDA-Audio
Posted: 17 June 2009 at 10:17pm |
mic not calibrated on sensitivity...
Ibex
Posted: 20 June 2009 at 10:42am |
Wow, so the sensitivity is pretty high! Such a tapped horn construction gets more and more interesting... i think i will build some to
![]() Did you have measured the 18" version to? Would be nice to see these plots as well! How do they sound compared to an WSX/WLX? |
rich_gale
Joined: 18 February 2008 Status: Offline Points: 2697 |
Posted: 22 June 2009 at 7:46pm |
hi TDA.
please can you post up the plan for your 12" version? id like to build one of these:)
Ibex
Posted: 22 June 2009 at 9:19pm |
Here is the plan of the original Staiper Design (better known as TH Mini by Danley Sound Labs) The only thing you have to do, is to reduce the cab high to 38/35cm (outer/inner dimension) and plug in the 12" instead the 15"... ![]() ![]() Maybe my tapped horn alternatives to the TH Mini are also interesting for you...? ![]() http://www.speakerplans.com/forum/peshkov-sub--scoop--tapped--arls_topic27673.html greez Edited by Ibex - 22 June 2009 at 9:28pm |
jethrocker
Joined: 07 June 2006 Location: Chiapas, Mexico Status: Offline Points: 1942 |
Posted: 23 June 2009 at 6:42am |
What is the 15" driver used in the staiper design Ibex?
Ibex
Posted: 23 June 2009 at 10:05am |
I don't realy know what driver staiper is using in this design, but i'm sure that the B&C 15TBX100, which tom danley uses in his TH-115, will work quiet well in this cab...
greez
TDA-Audio
Posted: 23 June 2009 at 9:07pm |
wsx and wlx(small brother) - monster sub tapped horn - compromise size\efficiency
I am a 15 " version did not use...
12nw100 - similar 12tbx100 other photo
Edited by TDA-Audio - 23 June 2009 at 9:08pm |
Page <12345 12> |
