Thunder ridge & IK mid tops |
Djdarch
Joined: 10 November 2005 Location: Newark, Notts Status: Offline Points: 1989 |
Topic: Thunder ridge & IK mid topsPosted: 20 June 2012 at 2:11pm |
Pictures of the system as promised.
Bass is 2 x sb2000 and 2 x sb1000 all kilomax 18a loaded i run these from 40hz up to 150hz then the mid tops are IK mids which were made by LOgic systems for ivor green. I've mounted a HF horn in the middle of these and the results are very good indeed. The mid is a 12" , a fane studio 12L which is a very very efficeint driver (102db in free air) so coupled to the horn it must be around 108db 1 watt 1 metre. i run these from 150hz up to 2.2khz. the top end is my favourite 1" a B&C de25 its on the B&C ME15 horn which is a 90 x 60 dispersion horn. I run these from 2.2khz to out. ![]() ![]() ![]() ![]() I have a these thunder ridge bins and then a set of 8 more sb1000, the bins in this set are a bit older than my other bins.
Herb-i
Joined: 22 November 2011 Location: Bolton Status: Offline Points: 275 |
Posted: 21 June 2012 at 12:33am |
Looking good there fella
Keith |
