Tit Boards |
Post Reply | Page 123> |
Rog
New Member Rogers Archive Posts Joined: 23 March 2010 Status: Offline Points: 2166 |
Posted: 14 February 2008 at 6:30am |
This is mainly for Jamie and Bryan and the other stasys users on here.
I've finished designing the new Stasys tilt boards and they are in stock. Or tit boards as I've called them as its always good to see a nice pair on them.
They will lock into place on top of a Stasys X and will also fit on a Stasys 8 but you lose the locking. There are 2 versions, the first version is for 2 Stasys 3's the second is for 3 Stasys 3's. Both versions will lock on to a Stasys X and will lock with the Stasys X is both vertical and horizontal positions. Longer tilt rods are available if you require more tilt. The tilt is adjustable form no tilt up to 30 degrees with the shorter rod in 7.5 degree steps.
Here's a few pics so you get the idea. Once the Stasys 3's are on the tilt boards its a one man job to set them to any angle you require. The new dollys and flybars are in stock too. Edited by Rog Mogale - 14 February 2008 at 6:38am |
TONY.A.S.S.
Hi Rog. That's a nice idea for a floor standing system. Better than lumps of foam and gaffer tape.
systemred.bill
Registered User Joined: 05 November 2007 Location: United Kingdom Status: Offline Points: 19 |
Mmmm, tiltage!
los hermanos bajos
system red - www.systemredaudio.com |
Rog
Yeah, got pissed off with people using creates of banana's to get some tilt, ha ha.
Thank you for you're comment Tony, it means a lot to hear that from the best cabinet fabricator ever.
Rog.
Preacher
Young Croc Joined: 06 February 2007 Location: United Kingdom Status: Offline Points: 1175 |
Yes, a very nice way of getting required tilt/angle on a stack |
Stone Lion Sound System, The Garden City Rockers. It's all about the music & the vibe.
jbl_man
Sorry Rog,i just read the title of this thread, "Tit boards" and was expecting a list of forums for the mentally-challenged.
but yeah,nice piece of kit...much neater than half-bricks.
Rog
Yeah, but not if I see you first.
Ben_Lawrance
Young Croc Joined: 12 January 2006 Location: Brighton Status: Offline Points: 919 |
I'm not a Stasys user, but i follow void quite closely.
I assume the tilt boards have the correct splay angle in place?
Even if you didn't need/want tilt, using the boards just to splay them correctly would a buying factor.
The amount of times i see people rock up with loads of pro kit, and then get an old tatty piece of mdf out to set there splay angles.
Good product Rog.
rezsbc
Registered User Joined: 21 November 2006 Location: Ireland Status: Offline Points: 352 |
how much $$$'s are we looking at for these? look very nice big improvement on our usual messy setup!
Heathrow_B_line
Old Croc Joined: 11 January 2006 Location: United Kingdom Status: Offline Points: 7344 |
has anyone got any links where i can buy those metal brackets [or anything similar] or the shelf at a decent price? they look they could be useful in all manner of different applications
TONY.A.S.S.
The only thing you'll be able to buy is the aeroquip stuff. The rest is custom made to suit the design.
Heathrow_B_line
woul mann flying systems have anything similar or would it be all customs jobs?
