Tit Boards |
Post Reply | Page <123> |
SteveAATW
Young Croc Joined: 04 September 2007 Status: Offline Points: 1173 |
Always thought boards like this were a good idea since I first saw the one for the Res 5s, quick and easy to setup with complete confidence all the angles are right
TONY.A.S.S.
Heathy, MAN Flying stopped business a few years back.
Rog
New Member Rogers Archive Posts Joined: 23 March 2010 Status: Offline Points: 2166 |
Nah, it's not a custom job, I got all the parts from my local Tescos. Have a look in aisle 6 next to the cucumbers and spam and you're see it.
In fact because Void have 10 CNC milling machines of there own to do all the metalwork we actually supply Tescos with there tilt board hardware. Wow, just had an idea. What if we kept back all the tilt board hardware we sell to them and used it for ourselves. That would mean I don't have to buy it from them. But wouldn't that be cutting out the middle man. Uuummmmmm............
Heathrow_B_line
Old Croc Joined: 11 January 2006 Location: United Kingdom Status: Offline Points: 7344 |
Rog what grade of steel do you use? BS970 347 S14 would be my guess, how close am i? Thank you for the useful comments, it has got me thinking and i am quite sure that B&Q stock all the parts needed to make DIY tilt boards. if not i can always pop into tescos as it is right night door. by the way, if anyone needs a good/cheap screw and bit set tesco do one for £4. Its really good as you get nut drivers with it as well to drive both M6 and M8 nuts... plus its so cheap you dont mind losing the bits [or people stealing them off you which i believeis what REALLY happens]
Rog
Hi Ben,
Yes the tilt boards maintain the correct splay angles, but I'm going to do myself out of some sales now and say that you don't have to have them to maintain the correct splay angles when you use the Stasys 3 with Stasys X. Stasys X is covered in loaction receptacles that mate with loactors on the bottom of Stasys 3. You can use Stasys X in both vertical and horizontal postions and still have the Stasys 3 dispersion correct. The tilt board is only needed if you have a high stack of bass cabs and need to get some tilt. Other than that the locators on both the bass cabs and mid tops allow the correct splay angles to be maintained in both vertical and horizontal mounting positions. i.e. bass cabs stood upright or on there sides. There are other loaction points on Stasys X that allow it to lock in with other Stasys X cabs. Again both vertical or horizontal positioning is catered for and the locking of bass cabs does not interfere with the other locating points used for setting the splay angles for the mid tops.
You can see a few of the locating points on this pic of the Stasys X.
Heathrow_B_line
Rog
We don't use steel for our hardware parts HBL as its too heavy.
Less critical components use 5052 aluminium, which as you know is used in aircraft manufacture. Critical components use a 7075 type aluminium magnesium alloy mix, with some parts using alclad to improve the corrosion resistance.
Don't know about the price of the tilt boards as I don't deal with money. But Void's accessories are normally sold just above cost as we see no point in penalising the customer after there initial purchase.
djstefanos
Old Croc Joined: 18 November 2005 Status: Offline Points: 2355 |
How much are the brackets? I have a couple of long throw cabinets very similar to the void but i don't think the tilt board fits them. I was thinking of building my own board using the same brackets
Edited by djstefanos - 15 February 2008 at 2:07am |
Rog
Thanks for the suggestion but the system is supplied with military spec locking pins like the type used for line array fly systems. These use a mechanical locking mechanism and a quick press of the button releases the pin.
Rog
The last time I got some from Tescos they were 39p, which really surprised me as the cucumber I had for lunch cost more.
Heathrow_B_line
i was refering to the DIY version of tilt boards, not your pro ones
SteveAATW
For a diy job given good enough front support and a groove cut in the board you could just put two strips of steel in the fly point track on the back of the cab, vary the position on the track to alter the angle that the steel strip pushes the cab off the back of the board. Will only give a limited range of angles but eliminates 3/4 of the metalwork.
Would just act like the 'biscuit' type thing in the bottom of Res 4 and 5's does, except you'd have a piece of metal either side rather than one in the middle |
