TMS3 10" mid driver help |
Lambo
New Member Joined: 30 June 2021 Location: Australia Status: Offline Points: 6 |
Posted: 30 June 2021 at 4:45am |
I have recently found myself in possession of a couple of TMS3 cabinets. Unfortunately the rear enclosures for the 10" mid range drivers are missing.
If anyone has or can take some measurements of the enclosures I would be eternally grateful. P.s. information on the material it is construction from also appreciated. Thanks in advance.
Robbo
Old Croc Joined: 05 December 2005 Location: Shropshire Status: Offline Points: 4226 |
Do you mean the cardboard tube and end cap that fit over the driver chassis and magnet in order to seal it?
Lambo
I do indeed
doller
Young Croc Joined: 19 July 2014 Location: japan Status: Offline Points: 509 |
QUIKRETE Tube Form in the Concrete Forms department at Lowes.com
maybe something like this might work. Just a suggestion. Just router out a piece of mdf or plywood to make the lid.
Lambo
Hi doller,
That was my plan to use some kind of industrial core.
Just need to find out the dimensions of the original tubes.
Boxes-R-Blue
Registered User Joined: 11 December 2018 Status: Offline Points: 147 |
A stack of 18mm MDF of correct dimms would work, if you are still stuck I can prob measure on of mine at the weekend...
You need a bit of Carpet underlay in there to damp the whole job, they bonk without it.. |
incasound
New Member Joined: 14 March 2019 Location: EDB Status: Offline Points: 7 |
Hi mate,are you in a rush for measurements ? I have tms3 stacked in the warehouse. Could have a look for you in the coming weeks once I arrange a couple hands to help me move the boxes ? Paul
Lambo
Good point with the carpet underlay. and yes if you have a chance measurements would be greatly appreciated.
Lambo
I'm in no rush mate. If boxes-r-us has easier access to his cabs save your spine. Thanks regardless.
