  New Posts New Posts RSS Feed - "To DUAL or NOT to DUAL, THAT is the question."
FUBARD303 View Drop Down
Contentiously righteous
Post Options Post Options   Thanks (0) Thanks(0)   Quote FUBARD303 Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2009 at 12:29am
It doesn't make a diference as long as you're talking about the same amount of gear in the same space respectively? So we're all in agreement that the only advantage of the dual cab is intimidation? In such case; I'm building singles cause they're easier to move. :)
"Always look on the bright side of life" -Brian
Glenn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Glenn Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2009 at 12:49pm
Question for deadbeat and the like:
No two drivers will be exactly the same due to quality control-
Fs maybe +/- 1hz
Vas maybe +/- 5L etc
for the same model of driver
So what is the effect of having two drivers (same model but inherent variation in specs) sharing the same volume. I know it will be negligible but surely it is worse than having a single cabinet for each.
