tonal character of reflex and horns |
Post Reply | Page <123> |
Hemisphere
Elliot Thompson, Master of Weasel Words. 'Properly designed', 'A lot of harmonic distortion'.
The question was posed generally, which type of design typically has more distortion: a reflex or a horn? 'Properly designed' can mean whatever happens to fit your argument. How about 'a typical reflex enclosure' or 'a typical horn loaded enclosure' - still very weasely but at least you take a good portion of subjective opinion out of the equation - A Funktion One cabinet is a typical horn loaded speaker. A 1850 loaded with an original 1850 is a typical horn loaded speaker, etc. A random build from the New Projects forum is not a typical horn loaded speaker. A new design which an amateur dreams up is not a typical horn loaded speaker. Obviously if you're developing a brand new horn design from scratch and you don't know what you're doing then you'll probably get better results with a reflex. If you can illustrate a single practical example in which a 1mm error in a folded bass horn design can result in an audible shift in distortion, that would be excellent.
If you want to define your terms and get into specifics, then you're making an argument, otherwise this is just bluster. Obfuscation even. It feels like you're intentionally setting out to confuse by ommitting detail and appealing to your own authority. |
The name of the topic is "Tonal Character Of Reflex And Horns."
Best Regards, |
JonB67
Which to be honest no one has answered.
Tonal character, not distortion. (So dont differentiate even if that's the source of the tonal character) And i believe the op wants subjective option. Heard both? Which did you prefer and why that sort of stuff This aint the scoop forum people. Take your argument elsewhere. |
jngggggggg
Registered User Joined: 27 April 2017 Status: Offline Points: 88 |
from my limited exposure to horn systems (mostly just F1), and reflex systems (pk), the reflex seems to have a more aggressive character while the F1s seem to be more natural and well rounded in sound - which stemmed my question of - is this perceived difference i hear due to BRvsHORN?
but as Elliott enlightened me, this may just be the reflex is able to go lower than the F1s ive heard. The pk subs i am accustomed to are specifically designed for bass heads and electronic music so this could very well be the reason. what about this stipulation: if a dual 18" reflex sub design to play to 30hz flat is side by side with a single 18" horn sub that can also play to 30hz flat, will there be any difference in sound? maybe thats a more apple-to-apple comparison?
Hemisphere
bee
Old Croc Joined: 14 June 2011 Location: Middlesex Status: Offline Points: 4553 |
I would say a reflex sub cabinet well designed, would have a lot less distortion (colouration) to a well built horn. Some horn designs (tapped horns) are close to a reflex and suffer less distortion.
But you cant look at the distortion (colouration) as a bad thing. For example scoops have a distinctive sound caused by the folding style, as do bph a different sound, same as a front loaded horn again sounds different. The sound differences are down the design differences. We commonly read distortion is bad but is it... Yes we should minimise distortion in the design stage, but natural colouration caused by the cabs design is what makes people love or hate scoops, bph, tapped horns ect.
Hemisphere
There's a reason why this thread has gone a bit scoopy: We're really into the realms of subjective taste and personal experience, much of which will be coloured by rose tinted glasses, intoxication, music program, system operator and other system components and processes besides the speakers, venue shape/size, vested interest, and a whole host of other complex physical and psychological factors. In other words it's a snake pit and you will never get to the bottom of it. My general experience is that horns sound cleaner than reflex, often to the point of feeling clinical and without character, however I've also heard horn systems that are growling and warm, and plenty of reflex systems that just sounded flat and awful. My personal understanding of the sense of 'warmth' and 'character' in sound reproduction is that this is distortion which I happen to enjoy the sound of. This makes sense to me from my experience of music production. Many producers routinely run their bass and synth notes through a distortion filter of some kind, or favour a set of analog processing/synthesisers which are naturally high in THD, to achieve a desired 'warmth' in their tracks. It could also be that the reflex systems I've found most enjoyable are operated with a similar approach - I know Opus systems which are mostly reflex frequently boast 'all analog processing' The best horn systems I've heard (at least to my ear) are the somewhat cobbled together ones, DIY designs, which by Elliot Thompson's reasoning should have more distortion, and maybe that's why I preferred them to more professionally designed horn systems, but my enjoyment may not be the same as your enjoyment, and could well be genre specific, not to mention all the other subjective factors I mentioned which makes my anecdote almost worthless. Placebo effect, and simply how you happen to be feeling on the day, or what your prior conceptions are about that system/operator or that kind of cabinet, can all colour your perceptions. Double blind listening tests with various bins would yield surprising and embarrassing results for a lot of people. Like wine tasting. I think there's a lot of 'Emperor's New Clothes' stuff going on with much hyped and feted brands like Danley and Funktion One. Neither have ever impressed me very much, but that could easily be down to the warmth/character/cleanness taste issues I mentioned. The difficulty with this discussion medium is that, what sounds good as articulated in words is hardly in any way related to what sounds good to you for your application as sound reproduced through a system in the real world. I could say 'build a box of this kind with this driver and it will have lower distortion than any of the alternatives!', which may be true and it sounds good to say it, but it might not be what you're looking for. I could also say 'build a box of this kind with this driver and it will have a warm, authentic character that makes your music sound just like it should!', again this might be true to me but it might not be what you're looking for, even if what you truly are looking for in a system is a warm authentic character that makes your music sound just like it should.
Edited by Hemisphere - 04 April 2018 at 8:20am |
bee
I'm not sure about a mm difference, but small changes do make a big difference, for the better and worse. I cant give actual details, but a design I done a few years ago, in proto stage was not sounding right. I ended up cutting an internal corner (horn) at a 45 degree only 10mm in each direction, the problem was cured. The problem being caused was a build up of air pressure, the 10mm cut sorted it out instantly. this was a sub cab. but mm differences in a hf cab or 12" mid high horn can make a major difference. to the way it sounds.
Hemisphere
When you measure the response of a speaker you get a squiggly line, and we just kind of accept that the flatter the line the better, but the nature of that squiggle obviously has an impact on the sound, and all the other measurable squiggles, same deal. Two musical waveforms that appear visually to be almost identical when plotted on a screen can sound completely different when played back through a system. It's a little different with loudspeaker performance measurements, but not completely. That's where it becomes seriously tricky to fairly articulate the difference between enclosure types, because we're all talking the language of "+/-3dB", "x% THD+N", "so many ms group delay", impedance spikes and so on. The chance that you can accurately convey a speaker's sound character to another person through such limiting terms is very slim.
Meat
Old Croc Joined: 05 June 2009 Location: Manc Status: Offline Points: 1514 |
Been following this thread and so far there's been very little discussion of phase or time-domain behaviour which is very important.
Horns and reflex are both really quite different in this respect. Don't have time for a long post so maybe others can elaborate. |
JonB67
Yes it was. If you want to carry on arguing you'll have to pay for another half hour.
JonB67
I don't agree. What's great about the question is that it wants a subjective view, not a technical treatise on what's causing it. Sometimes the truth gets in the way of a useful answer.
So are they warm and subby, lots of kickky, hard and attacking soft, whatever? |
