tonal character of reflex and horns |
Post Reply | Page <123 |
It depends on the design. Funktion One offers various bass horns for a particular type of application. Bass reflex cabinets can be tuned to a particular frequency for a certain type of application. It would be best to listen to a wide variety of Folded Horns and Bass Reflex designs from different manufactures before making a decision. No matter what anyone tells you, your ears are the deciding factor.
Yes that would be a more of an apple to apples comparison. The tone amongst both designs should sound similar under the given scenario Bear in mind enclosure size would come into play. A folded-horn capable of achieving 30 Hz flat would be significantly greater than, the Dual 18” reflex sub in terms of size. Minimaxal (an old Speakerplans member) designed the Terra Horn. You may want to contact him if you really want to invest in a 30 Hertz Folded Horn. http://www.metaacoustics.com/terra.html Best Regards, |
gen0me
I think designing a big horn is very easy. From sim point of view. Those small pushed to limits horns can be sensitive for change.
Time domain: for br it has 1 huge peak at the bottom, for classic horns 2 peaks. It important in crossover. But its tops topic If you use portred tops with front loaded horns you should avoid crossing on port. I think tapped horn should take crosing on port due to axe crossover and not playing any kick through. ... If you like songs like Flux Pavilion - Bass Cannon build yourself tapped For Matstubs - War front loaded horn Listening to reflex I personally have feeling like the speakers are pushing the air instead of playing it like there was some unmusical waste.
Hemisphere
gen0me
I hate it feels like it shouldnt be there.
Large companies have push towards size or numbers. Diy maniacs dont have to care about its transport usefulness.:) Those badmans Battleaxes, longsquares(?) Or terrahorns dont have client limitations Edited by gen0me - 04 April 2018 at 4:35pm |
bee
Old Croc Joined: 14 June 2011 Location: Middlesex Status: Offline Points: 4553 |
Hemisphere
It's possible that we're talking about different effects, Gen0me, but perhaps not.
For me music playback through a rig is as much, and possibly moreso about the totality of the experience as it is about the accurate and clean reproduction of the signal. I would probably enjoy an event that artificially blasted air and vibrated the dancefloor in program with the music signal.
nickyburnell
[/quote]And what you describe sounds a lot like what I like about reflex systems![/QUOTE]
+1 |
valve head777
Old Croc Joined: 27 July 2012 Location: East Sussex Status: Offline Points: 1781 |
One of the issues here is program material. How can a discussion be had on the subjectivity of two types of speaker enclosure without a standardized program source? Mixing techno on a f1 rig might sound good for that genre, but is it accurate? How would a classical piece sound?
The intelligibility and realism of a single human voice is a good way to judge studio monitors etc. This is why a discussion like this brings out the bs. Imho.... |
Hemisphere
Agreed. I actually think it would be much more productive for the OP if we addressed the specific conundrum he's facing which is basically: big hog + horn kicks system or compact two way reflex (or could be reflex and kicks) system for 150 cap indoor dub/reggae/dnb events.
Narrowed down to those specific system designs and genres it should be possible to draw an accurate picture of the tonal differences between horns and reflex.
gen0me
Ofc changing sim into Cad design is the most time consuming and hardest step. I didnt express myself correctly. Here is badman's :). Here goes my 15" I mentioned: Now. Huge horn has space to mount speaker from side. The mounting only affects its rear chamber volume Vrc. The rear chamber 2dm3 change on its hornresp sim affects sound as tv satelites affect ocean movement. There is ofc 180deg bend. The topic of bending length is totally solved on diyaudio topic, but even worst case scenario lets say 10cm difference on sims wont change much. Expansion crosssurfaces can be calculated than. Now take a look on Csize15 . Its offset arangement. So L12 has to be length from front piece of plywood to middle of the driver. How would you measure this length exactly on the design? And worse how would you choose its expansion correctly on the sim.Con,Exp or Par? You cant change the speaker hatch. There is no space on the side. Ofc every another offset sim has the problem with incalculable cone expansion but in comparison to Battleaxe this small sim is very sensitive to any changes. Add ribs. Than add to this "speaker occupied by volume" volume change of the rear chamber(also sim very sensitive) and possible pole mounting, handles. And also a neo version...
When your pants are shaking to the BRs you have a feeling that they are not shaking to the sound but in some different way. When they are shaking to the huge horns this shake is kind of perfectly synchronized and harmonic. Edited by gen0me - 05 April 2018 at 8:25am |
