Tony Wilkes Q12x2 Sub + 2x8 Top |
Page 12> |
LeNNNseN
Topic: Tony Wilkes Q12x2 Sub + 2x8 TopPosted: 13 October 2021 at 5:18pm |
Hello everybody,
i am new in this forum and i have a question. I heared that a guy called tony builds a double 12 inch subwoofer with double 8 inch tops in the past. He sent his plans to everybody who asked for it. Is here anybody who has his plans and would share it? I know that he dies for a few years - very sad . God bless him. i asked this question, because i have two bms 12n630 woofers and i want to build a sub like he did. Sorry for my bad english - i am from germany. Greez ![]() LeNNi
DMorison
Joined: 14 March 2007 Location: Aberdeen Status: Offline Points: 1740 |
Thanks(1)
Posted: 13 October 2021 at 9:11pm |
Forum member "Bee" was the keeper of Tony's plans as far as I recall, once you have been around long enough to accumulate at least 10 points you'll be able to PM him and ask.
Or you might be able to contact him through his business, Elements Audio. PS, no worries about your English, it's still about 3x better than most British people's attempts at speaking foreign languages!
JonB67
Joined: 22 April 2016 Location: UK Status: Offline Points: 1352 |
Posted: 14 October 2021 at 7:23am |
Ben (bee on here) at elements audio is a very busy guy but keep trying he'll give you what your after.
Normally just asks for a donation to the british heart foundation in tony wilkes memory. |
LeNNNseN
Posted: 25 November 2021 at 8:53pm |
Okay guys, it's not possible to register on his page -.- wtf. i cannot write a pn in this fourm cause i dont have enough points... this makes me sad. Can someone help me? Can someone write him an pn?
... greez
JonB67
Posted: 25 November 2021 at 10:03pm |
Try elements audio on Facebook.
markie
Joined: 31 October 2005 Location: Sunny Liskeard. Status: Offline Points: 4568 |
Posted: 26 November 2021 at 11:29am |
I have a copy of the original Q12 that came from Tony himself back in 2015. I believe the 2x12 box was simply double width.
You only have to post 7 more times and you can use the PM system. Reply to this, then post a "Hi I'm LeNNsen from Germany plus 5 more and you can PM me.
LeNNNseN
Posted: 26 November 2021 at 8:08pm |
@markie , thank you dude! if i could, i would spend.
LeNNNseN
Posted: 26 November 2021 at 8:09pm |
i need to post im sry guys....
LeNNNseN
Posted: 26 November 2021 at 8:45pm |
i need to post im sry guys....2
LeNNNseN
Posted: 26 November 2021 at 11:30pm |
i need to post im sry guys....3
markie
Thanks(1)
Posted: 26 November 2021 at 11:37pm |
Here's some info from Tony back in 2015:-
"This design is a compromise between extension and size, its -3db is 43hz and it is -10db at about 35hz. it has no problem with Xmax limitations 40hz up at full power. To get the correct tuning for the box it needs to be lined with 50mm egg box foam or similar, also make sure you sit the driver down on a foam gasket, I use some stuff from a guy on Ebay, Tony" Edited by markie - 26 November 2021 at 11:37pm |
markie
Posted: 27 November 2021 at 12:04am |
So does that sound like a cab that will fill your needs???????
Page 12> |
