Schematic / Manual Vestax PVC275 |
Meat Substitute ![]() Registered User ![]() ![]() Joined: 10 July 2020 Status: Offline Points: 57 |
![]() ![]() ![]() ![]() ![]() Posted: 06 December 2022 at 10:12am |
You should have that now. Let me know if it needs resending.
T C ![]() New Member ![]() ![]() Joined: 01 December 2022 Location: New Zealand Status: Offline Points: 2 |
Hey
Awesome. Thankyou. Yes I've only just signed up. As it turned out , I've managed to get both turntables and amp running. Luckily just fuses had blown . Not sure what I posted earlier but have modified the tranny in turntables to take 240v from a YouTube clip but running vestax mixer through a an exterior additional tranny. Be keen to see a service manual . tom.star@windowslive.com Thanks again. Tom
Yeah, still got it. Can't send it via PM on here as you've less than 10 posts but if you put up your email I can send what I have.
Hi Meat
I recently purchased one of these mixers and two vestax turntables online. Turns out it's 100v gear not 240v which is what we have here in NZ. Looks like all three have been plugged in to 240 v . Fuses had all blown and the turn tables after a transformer mod I found seem cooked I'm guessing the same for the mixer but looking for a service manual to help. When typing in search your thread came up and I see you thanked someone for the service manual. Any chance you still have access and could share ? Thanks. |
You should have that in your mailbox now...
dbizaro ![]() New Member ![]() ![]() Joined: 17 November 2020 Location: se uk Status: Offline Points: 2 |
HI
thanks that would be great once i have i will delete this message dan@itsaliveltd.com i do remember parties and working in clubs and festivals. stay safe thanks dan |
Also, the mixer is still running after all the tinkering 2 years ago. Wish I had more opportunity to use it myself but hey it was fun using it to mix at parties on in the beforetimes! Remember parties with lots of people and dancing? Them were the days.
Yes, I've still got all the docs I collected for the PCV-275. Can't get into my old account so I won't be able to send/recieve PMs until I've got 10 posts. If you put up your email I can send what I've got.
HI do you still have this service manual or schematic
i have a mixer not powering and possibly has other issues - nights what i have been told Thanks anyone that can help Dan
Sounds like it very much could be. Had it once before. Check all ribbon cables and board-board connector seatings for a start in the Berry. Good luck!
Meat ![]() Old Croc ![]() Joined: 05 June 2009 Location: Manc Status: Offline Points: 1514 |
Got the little bugger on the scope today. Seems pretty nice. No problems at all.
Took it home. Ran just headphones, no problems. Plugged it into my ultradrive... ...HF noise present again. I went rooting and turned up my horns; it's present without the mixer. So in all, my ultradrive is putting HF noise out of the inputs and the outputs. I think this vestax story is wrapped up for now! Is this the famous 'frying eggs' ultradrive thing? Anyway, it's probably time to just start another topic. Thanks to all those who have helped or offered advice. |
Thanks to member sunpro I have the service manual now. Cheers for that
