  New Posts New Posts RSS Feed - Little or large
Little or large
MINTEVENTRESOURCES View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MINTEVENTRESOURCES Quote  Post ReplyReply Direct Link To This Post Topic: Little or large
    Posted: 20 September 2018 at 9:45pm
Originally posted by Dub Specialist Sound Dub Specialist Sound wrote:
whats the Super 914 scoop , pretty sure not many kno that scoop in the uk
Thoughts?
Mint Event Resources
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dub Specialist Sound Quote  Post ReplyReply Direct Link To This Post Posted: 20 September 2018 at 9:32pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote MINTEVENTRESOURCES Quote  Post ReplyReply Direct Link To This Post Posted: 20 September 2018 at 9:18pm
Mini Scoop over Full Size???... this will start another war. I just want to know if anyone has really built the Super 914 and how does it perform... Seems you are saying build the mini over the Super 914.
UpComingSound View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote UpComingSound Quote  Post ReplyReply Direct Link To This Post Posted: 20 September 2018 at 9:03pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote MINTEVENTRESOURCES Quote  Post ReplyReply Direct Link To This Post Posted: 13 September 2018 at 7:49pm
Has anyone built and used the Super 914? I am interested in this design any feedback on this one? What does this version sound like and will the Ciare SW18 work well in this box?
nickyburnell View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nickyburnell Quote  Post ReplyReply Direct Link To This Post Posted: 22 March 2018 at 7:47am
Well I could see that it would always want a bigger driver, but have to admit wasn't prepared for 220w. Little knowledge etc.  Shame, I was prepared for 500w and would have been happy at that as I have 650ish proper watts for each driver.
 Almost relieved, that's a lot of wood
Aman Gebru View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Aman Gebru Quote  Post ReplyReply Direct Link To This Post Posted: 22 March 2018 at 2:11am
Originally posted by Aman Gebru Aman Gebru wrote:
Could always build the Super 914.
Works great with the Xb.
Ha ha, not really.
As some may have speculated, 914 scoop needs PD1850 or V18-1000 or even stronger motor to work. Mush motor like 18 XB will have a massive dip in Pmax at 45Hz and will be down to 220 watts handling around 45Hz. V18-1000 will have no problems with Pmax and will be able to accept 1000 watts from 27Hz and up, all the way though its passband.
Yep you guessed it, black line is V18-1000, red is 18 XB.
The XB just doesn't have a strong enough motor to control all the air in the long horn behind it. Pmax isn't too important and shouldn't be 'the' deciding factor for output SPL, but if what goes in comes out then 1000 watts is going to make more noise than 220 watts, assuming efficiency is similar between both drivers.
Edited by Aman Gebru - 22 March 2018 at 2:13am
Post Options Post Options   Thanks (0) Thanks(0)   Quote nickyburnell Quote  Post ReplyReply Direct Link To This Post Posted: 21 March 2018 at 6:20pm
Cool thanks
luton_soundman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote luton_soundman Quote  Post ReplyReply Direct Link To This Post Posted: 21 March 2018 at 5:28pm
uk dub has plenty. Certain producers pre warn you about the freq in some of their tunes and check you can reproduce it first Big smile
Post Options Post Options   Thanks (0) Thanks(0)   Quote nickyburnell Quote  Post ReplyReply Direct Link To This Post Posted: 21 March 2018 at 4:20pm
Oh stop it Mr Gebru. I was going to actually use the SL1200 plans at last!
Gone a bit quiet but the global horsrep use just went up a few %.  Plenty used scoops about to hit the market, all they need now is some music that actually HAS 31hz.......Coat on
BeerSir
Edited by nickyburnell - 21 March 2018 at 4:24pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Aman Gebru Quote  Post ReplyReply Direct Link To This Post Posted: 21 March 2018 at 2:32pm
paulus View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote paulus Quote  Post ReplyReply Direct Link To This Post Posted: 21 March 2018 at 2:15pm
if was me would build emni scoop make 620 wide, then later on if you change from fane to bigger driver it will work on both , add 36mm mouth bracing and internal bracing boooom :) you will be surprised the out put you get from 2 full size scoops compared to "most" minis apart  from the hardcore un free plan ones
Edited by paulus - 21 March 2018 at 2:16pm
TRENDSETTER SOUND SYSTEM
