  New Posts New Posts RSS Feed - Crown Macro tech 5002vz 😞😞😞
Kendry castro View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kendry castro Quote  Post ReplyReply Direct Link To This Post Topic: Crown Macro tech 5002vz 😞😞😞
    Posted: 26 May 2018 at 8:33pm
brothers I ask you please help me with this problem I have a crown amplifiers Mach 5002VZ and I want to put it at 220 vol I want someone to send me a video of what are the wires that I have to move thank you very much for your valuable time and thanks
DjLeco View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DjLeco Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2018 at 11:14am
I put one red circle for 230Vac operation
https://s19.postimg.cc/3pfp5jvz7/Voltage_Conversion.jpg
I'm A Stupid SMART Romanian...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kendry castro Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2018 at 7:33pm
?I do not know which wire I have to move
Post Options Post Options   Thanks (0) Thanks(0)   Quote DjLeco Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2018 at 9:47pm
You have there three groups of wires and each have his own set of names on PCB.
I red circled each group of wires, group 1, group 2, group 3, all on main PCB.
So for 230Vac supply we must arrange wires as it follows for each group of 3:
ON GROUP ONE (first transformer)
on pin P712 must be black wire
on pin P711  no wire (leave it empty)
on pin P724B must be blue wire
on pin P707 must be black/yellow wire
on pin P704 must be white wire
on pin P705 must be black/green wire
on pin P710 must be white/yellow wire
on pin P709 must be white/green wire
on pin P708 must be white/red wire
on pin P703  no wire (leave it empty)
on pin P701 must be grey wire
on pin P700 must be grey wire
on pin P702 must be green/yellow wire
On GROUP 2 (middle one):
on pin P713 no wire (leave it empty)
on pin P714 must be white/red wire
on pin P722 must be brown wire
on pin P749 must be white/green wire
on pin P750 must be white/yellow wire
on pin P718 must be black/green wire
on pin P716 must be white wire
on pin P721 must be black/yellow wire
on pin P719 must be black wire
on pin P715 no wire (leave it empty)
on pin P724A must be blue wire
ON GROUP 3 (second transformer)
on pin P736 must be green/yellow wire
on pin P735 must be grey wire
on pin P734 must be grey wire
on pin P742 no wire (leave it empty)
on pin P737 must be white/red wire
on pin P744 must be white/green wire
on pin P743 must be white/yelolow wire
on pin P738 must be black/green wire
on pin P739 must be white wire
on pin P745 must be black/yellow wire
on pin P724C must be blue wire
on pin P741 no wire (leave it empty)
on pin P740 must be black wire
READ and watch CAREFULLY multi times this, and check multiple times too to all colours of wires to correspond/match as I wrote above:
Good luck!
Edited by DjLeco - 27 May 2018 at 9:49pm
spongebob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote spongebob Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2018 at 9:58pm
I suspect this person should just take it to someone who knows what they're doing now rather than after they've messed the wiring up and blown it up.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DjLeco Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2018 at 9:39am
If it will do exactly what I showed above, and no mistake, the amp will be easy configured to 230Vac
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kendry castro Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2018 at 12:20pm
?thank you very much brother can do it and now he is working excellent thanks again 😁😁😁😁
APC321 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote APC321 Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2018 at 1:05pm
What great advice you got from DjLeco!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kendry castro Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2018 at 1:22pm
dj leco he sent me the colors and maggie number but thank God and dj leco
Edited by Kendry castro - 28 May 2018 at 1:25pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DjLeco Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2018 at 6:19pm
Always with pleasure dear colleagues!
I hope this will help others to configure Power Supply Settings for VZ 500x series.
Is not hard!
