  New Posts New Posts RSS Feed - Loud & powerful15" drivers for single bass reflex
Crashpc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Crashpc Quote  Post ReplyReply Direct Link To This Post Topic: Loud & powerful15" drivers for single bass reflex
    Posted: 26 December 2018 at 5:08pm
I haven´t seen single Tapped Horn, that would be as powerful in the particular box size, as Bassreflex box. One can always get more from the driver in a horn, but not in the same volume of one bassreflex box with one driver. Horns are large, and TH doesn´t solve this issue completely.
Edited by Crashpc - 26 December 2018 at 5:10pm
Nikon and Canon people should not be married to each other. Why did you let this happen?
JonB67 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JonB67 Quote  Post ReplyReply Direct Link To This Post Posted: 12 July 2018 at 10:57pm
Its designed around the b&c  15tbx100 so that's a safe bet.  I think they do a neo version if you want them a bit lighter too.
djrobs View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote djrobs Quote  Post ReplyReply Direct Link To This Post Posted: 12 July 2018 at 10:20pm
Originally posted by APW APW wrote:
150 people, a pair of tham-12s will do that if you need small... they don't drop overly low but are loud and efficient for their size (at about 100db/watt), when used with the Beyma 12LX60v2 driver can take one hell of a beating and will still put a smile on you face!!
Plans for all the Tham range are on Martinssons site.
 http://www.martinsson.cc/blog/static.php?page=static140228-173656
 This might be of interest to you:
https://forum.speakerplans.com/compact-subs_topic99262_page2.html?KW=tham
great thanks i will tried the 12" but will start  whith the 15"
what 15" driver do recommend for loudes as possible
Regards Rob
APW View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote APW Quote  Post ReplyReply Direct Link To This Post Posted: 12 July 2018 at 8:05pm
Edited by APW - 12 July 2018 at 8:14pm
Shortrope View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Shortrope Quote  Post ReplyReply Direct Link To This Post Posted: 12 July 2018 at 8:01pm
google is your friend.
There’s a whole blog on them with all the info you need.
My Tinnitus is coming along nicely!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote djrobs Quote  Post ReplyReply Direct Link To This Post Posted: 12 July 2018 at 7:52pm
Originally posted by Shortrope Shortrope wrote:
Build some Tham 15, you won’t be disappointed.
okey looks like most of you recommend  Tham 15 horn. what drivers should i use and where can i find Blueprints or how to build one.
thanks
Regards Rob
Originally posted by Dutchman Dutchman wrote:
+1 for tham 15. Cheap, easy to build and proves it self worthy.
thanks
Regards Rob
Dutchman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dutchman Quote  Post ReplyReply Direct Link To This Post Posted: 12 July 2018 at 7:39pm
We need more SPL!
Post Options Post Options   Thanks (0) Thanks(0)   Quote djrobs Quote  Post ReplyReply Direct Link To This Post Posted: 12 July 2018 at 7:19pm
i have prophon 12” and Martin audio blackline 12” and Rcf art 310
Regards Rob
fatfreddiescat View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fatfreddiescat Quote  Post ReplyReply Direct Link To This Post Posted: 12 July 2018 at 6:45pm
What are you going to use above them?
Post Options Post Options   Thanks (0) Thanks(0)   Quote djrobs Quote  Post ReplyReply Direct Link To This Post Posted: 12 July 2018 at 6:40pm
looks like tapped horn are the one to go.
I have allways used br boxes thats way
Ist the any blueprints and What driver is god?
Regards Rob
Post Options Post Options   Thanks (0) Thanks(0)   Quote djrobs Quote  Post ReplyReply Direct Link To This Post Posted: 12 July 2018 at 6:36pm
i just want something small but Powerfull
Not all my djs that work for me have Big cars thats why.
400€ its for 1 driver
I have few Lab amps lie fp10000 fp14000 Lab 2000
Etc so i have Power.
And i Also have 4 double 15” br jbl 2226
And rcf8006as if i need lots off Power .
But iam looking for ”small” box that give me lots off Puch for a party up 150 persons mor o less  i now more Power more boxes.
For me its easier to build br but have any god tapped horn that you recommend and How to build? What driver for that ?
Regards Rob
