  New Posts New Posts RSS Feed - Turbosound Floodlight restoration pictures!
tmwautier View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tmwautier Quote  Post ReplyReply Direct Link To This Post Topic: Turbosound Floodlight restoration pictures!
    Posted: 31 July 2018 at 10:31pm
might be interested depending on pricing/your location etc. (landed costs)
rubjel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rubjel Quote  Post ReplyReply Direct Link To This Post Posted: 30 July 2018 at 3:02pm
Which only proves that without any precise measurement you can not just apply any sort of crossover point to any HF driver.
Yes, one cannot expect to get good results only by looking at spec sheets and applying theory.
There are many circumstances that combine to produce the resultant response.
Edited by rubjel - 30 July 2018 at 3:04pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote MarjanM Quote  Post ReplyReply Direct Link To This Post Posted: 30 July 2018 at 2:10pm
Originally posted by rubjel rubjel wrote:
Originally posted by Hvedstrup Hvedstrup wrote:
I seriously doubt that a big difference can be heard above 8k. With correct gain structure the 1" doesn't work very hard in the Floods since the 6.5"  is so bloody efficiant.
If you are not able to hear the difference between an EV DH3 and TAD 2001, I would say you are suffering from hearing loss. I find the EV to be very harsh and unpleasant.
Even if the electrical XO is 24dB LR at 8khz, this does not necessarily mean that the HF is down 24dB at 4Khz, acoustically. I measured -15dB on axis at 4khz in this configuration. So there is still alot of contribution even below 6khz. Looking at the equal loudness contour, our ears are still very sensitive in this range.
You are of course entitled to your opinion, but I struggle to see how an opinion can be formed without actual experience.
Not sure what you mean by gain structure in this context, as this is something that applies to the signal chain. The amplitude is of course level matched to meet the 6.5".
Post Options Post Options   Thanks (0) Thanks(0)   Quote rubjel Quote  Post ReplyReply Direct Link To This Post Posted: 30 July 2018 at 1:34pm
mattd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mattd Quote  Post ReplyReply Direct Link To This Post Posted: 30 July 2018 at 9:43am
I have an absolutely mint Floodlight 760 if anyone might need a single one. Was sat in F1 factory for years and years literally is mint, original paint job, no chips or dents at all. I bought it meaning to buy two more but keep buying other rig so if anyone needs a third in perfect nick with all original un-gigged drivers let me know. Guy I bought it from did the same as me bought it then just sat on it.
Hvedstrup View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hvedstrup Quote  Post ReplyReply Direct Link To This Post Posted: 30 July 2018 at 9:21am
Post Options Post Options   Thanks (0) Thanks(0)   Quote rubjel Quote  Post ReplyReply Direct Link To This Post Posted: 30 July 2018 at 9:00am
Hi Kyle, thanks for the tip. The 475Be does not sound as good as the TAD 2001,
even with the shorter throat. The Beyma CP380 is actually very good for this horn, and much cheaper.
Best Regards,
RB
Post Options Post Options   Thanks (0) Thanks(0)   Quote toastyghost Quote  Post ReplyReply Direct Link To This Post Posted: 29 July 2018 at 12:18pm
Yes those are TAD 2001. The throat geometry/exit angle is not perfect for the HF horn, but still sounds ALOT better than both the original EV DH3 and BMS 4540nd. Crossover to the 6.5" at 6.5k to get more of that brilliant beryllium sound.
LS-1209 was £266 each ex. VAT and LS-6503 was £206 each ex. VAT.
The Radian Beryllium might be worth a look for a fancy option that fits a little better
londonavc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote londonavc Quote  Post ReplyReply Direct Link To This Post Posted: 26 July 2018 at 10:36am
excellent work
Post Options Post Options   Thanks (0) Thanks(0)   Quote rubjel Quote  Post ReplyReply Direct Link To This Post Posted: 25 July 2018 at 6:57pm
Sypa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sypa Quote  Post ReplyReply Direct Link To This Post Posted: 25 July 2018 at 5:43pm
What's the pricing on the 12s?
Cyklist View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Cyklist Quote  Post ReplyReply Direct Link To This Post Posted: 25 July 2018 at 5:16pm
Aare those TAD comps above?
Did you fit into tfl760?
purple monkey dishwasher
