  New Posts New Posts RSS Feed - 21" Ported Horn design idea
hectorberman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote hectorberman Quote  Post ReplyReply Direct Link To This Post Topic: 21" Ported Horn design idea
    Posted: 24 April 2023 at 10:24pm
This seems to be a very similar layout to Ricci's other design, the SKRAM.
I'm toying with the idea of designing something of a similar nature, and have been considering attempting a larger double 15" loaded design following the design principles of the skram.
I'm not too experienced in cabinet design, so would appreciate any input.
In my head this could be more cost effective power density, and potentially higher sensitivity? Or is this a silly goose to chase...
smitske96 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote smitske96 Quote  Post ReplyReply Direct Link To This Post Posted: 02 February 2022 at 2:24pm
@bob4
2,6m seems doable with those dimensions.
AlphaC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AlphaC Quote  Post ReplyReply Direct Link To This Post Posted: 02 February 2022 at 1:52pm
That Seeburg box looks like the old Martin Audio ported horns.
Which Martin model do you refer to? I'm not aware of any similar design.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MarjanM Quote  Post ReplyReply Direct Link To This Post Posted: 29 November 2021 at 7:36pm
bob4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bob4 Quote  Post ReplyReply Direct Link To This Post Posted: 29 November 2021 at 4:29pm
Originally posted by smitske96 smitske96 wrote:
Am I correct in thinking that they tune the BR port high and the horn low?
Isnt that very unlikely, since you need lab horn size for real 30 hz horn loading (in multiples of four!!)
I would have guessed the reverse Confused
Edited by bob4 - 29 November 2021 at 4:29pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote smitske96 Quote  Post ReplyReply Direct Link To This Post Posted: 29 November 2021 at 1:40pm
Yes, but it even has a similar/higher sensitivity @50Hz than for example a BC218.
According to the measured response peak sensitivity is around 111/112dB @+-150Hz, which does fall out of the desired bandwidth but still is pretty high.
If I may ask, which design are you talking about regarding the vent also tapping in the horn mouth?
Post Options Post Options   Thanks (0) Thanks(0)   Quote toastyghost Quote  Post ReplyReply Direct Link To This Post Posted: 29 November 2021 at 9:52am
In all other quick sims, I can not reach such 2,83V sensitivity figures.
I would treat the Seeburg as a variant of tapped horn, rather than a rear ported horn. It’s very dark in the renders, but I have a feeling that the driver ‘vent’ also opens into the horn mouth based on a similar design I saw elsewhere.
Also that’s the peak sensitivity value in the specs. Not the average.
Edited by toastyghost - 29 November 2021 at 9:53am
Post Options Post Options   Thanks (0) Thanks(0)   Quote smitske96 Quote  Post ReplyReply Direct Link To This Post Posted: 29 November 2021 at 9:38am
Post Options Post Options   Thanks (0) Thanks(0)   Quote smitske96 Quote  Post ReplyReply Direct Link To This Post Posted: 22 November 2021 at 8:42am
bob4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bob4 Quote  Post ReplyReply Direct Link To This Post Posted: 30 July 2021 at 4:00pm
Kevin, we would like to build your ported horn, any chance of getting a set of plans?
Fracture_clinic View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fracture_clinic Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2020 at 1:38pm
I cant install Hornresp on my machine (admin issues) can anyone speculate these changes please?
1) larger chamber all else the same
2) larger chamber and horn extended through 90 degrees (over the port exits) and along width of box. Assume ports are relocated + ignore external dims for now.
3) Same as above but with chamber remaining the same.
Asking a lot I know - until lockdown is over I can't jump on a buddies laptop to try myself.
Not asking for sims just interested in bouncing ideas around.
TIA
Edited by Fracture_clinic - 14 May 2020 at 1:40pm
NiToNi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NiToNi Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2020 at 12:59am
+1
Would love to have a go at this mate!
... although slightly lower corner at 27 Hz would have been perfection Wink
