  New Posts New Posts RSS Feed - 18sound 18” Dual Subwoofer build
itskabini View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote itskabini Quote  Post ReplyReply Direct Link To This Post Topic: 18sound 18” Dual Subwoofer build
    Posted: 06 July 2021 at 11:18pm
I was after the fusion file with all the bracing improvements, hoping to be able to give the cabinet builder a bit more detail than just the 18Sound plans.
Also would making it into a single 18 be as simple as cutting this box in half, to effectively get two triangular vents similar to he B&C sub18
Post Options Post Options   Thanks (0) Thanks(0)   Quote MarjanM Quote  Post ReplyReply Direct Link To This Post Posted: 06 July 2021 at 11:14pm
Its at the 18sound web site.
Post Options Post Options   Thanks (0) Thanks(0)   Quote itskabini Quote  Post ReplyReply Direct Link To This Post Posted: 06 July 2021 at 10:05am
I'd like a copy of that file too if possible. Hoping to get a few of these built soon, although might try and modify it into a single 18 design.
Edited by itskabini - 06 July 2021 at 10:06am
DanielIt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanielIt Quote  Post ReplyReply Direct Link To This Post Posted: 20 March 2020 at 9:32am
Hey Willi...can you share your fusion file for this build? Would love to take a look at that bracing.PM me please .
Measure twice...cut once.
wilidapili View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wilidapili Quote  Post ReplyReply Direct Link To This Post Posted: 16 August 2019 at 12:03am
Originally posted by ole123451 ole123451 wrote:
Im not sure how I send you a private message, so here you have my email:
danielpedersen650@gmail.com
Oh yeah you cannot send private messages before having 10 or so messages on the forum. I sent you an e-mail.
ole123451 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ole123451 Quote  Post ReplyReply Direct Link To This Post Posted: 16 August 2019 at 12:00am
Post Options Post Options   Thanks (0) Thanks(0)   Quote wilidapili Quote  Post ReplyReply Direct Link To This Post Posted: 15 August 2019 at 10:11pm
Skram is a 30Hz box, so i fail to see how it will go lower then the 18sound 2x18 box. And it wont be louder for sure.
The tuning can be dropped by blocking a vent. Also, we'll see the comparison regarding loudness SmileAtleast two will be louder than one 218 box, which will be about the same driver and amp cost. Also it might have nicer dimensions. I don't know what I want yet Smile
Post Options Post Options   Thanks (0) Thanks(0)   Quote MarjanM Quote  Post ReplyReply Direct Link To This Post Posted: 15 August 2019 at 10:02pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote wilidapili Quote  Post ReplyReply Direct Link To This Post Posted: 15 August 2019 at 9:34pm
What kind of speaker did you use for this subwooferbox? Did you just go with the Eighteensound 18LW3000 as they suggested?
Yes, we used the 18TLW3000. We have made two of these subwoofers, and they sound really, really nice. However, I am starting to build a prototype for a new subwoofer design called the "Skram" by Josh Ricci, just to get a little bit more lower extension. If you are interested, I am thinking about selling both of our double 18's. I could bring them to Denmark as I will be driving there during the fall/winter months. They have barely been "driven in", and have been used for only 4 gigs, all with a Powersoft amp and with all limiters in use, so they haven't been abused in any way. DM me if you are interested. Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote ole123451 Quote  Post ReplyReply Direct Link To This Post Posted: 09 August 2019 at 10:31pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote wilidapili Quote  Post ReplyReply Direct Link To This Post Posted: 20 January 2019 at 11:02pm
Sooooo.... Finally got some measurements done. Here is the frequency response of the sub, if anyone is interested. We ran the sub with a Powersoft X4 amp and through a Biamp Nexia DSP. Measured with Behringer ECM-8000 mic on same level as and about 2 meters from sub into an Audient ID4. Still learning about delaying and phase (polarity) alignment etc.
Unprocessed (actually forgot to take the +8dB gain away) and processed with recommended settings from the original plans:
With the kick:
Edited by wilidapili - 20 January 2019 at 11:07pm
supremesoundz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote supremesoundz Quote  Post ReplyReply Direct Link To This Post Posted: 28 October 2018 at 6:47am
more pics as and when. Great workClap
This page was generated in 0.059 seconds.
