  New Posts New Posts RSS Feed - best "little"  sub driver
stevie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote stevie Quote  Post ReplyReply Direct Link To This Post Topic: best "little" sub driver
    Posted: 20 November 2018 at 4:26pm
If you want the best, that would probably be the Faital Pro 8PR200.
markie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote markie Quote  Post ReplyReply Direct Link To This Post Posted: 20 November 2018 at 9:37am
As I said it's an old model, the LS201. It's on the winisd driver data base if you want to check out the performance.
_Natty_ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote _Natty_ Quote  Post ReplyReply Direct Link To This Post Posted: 20 November 2018 at 9:30am
Originally posted by markie markie wrote:
I have a couple of VOLT 8" studio drivers. They are an old model but have not been used since a factory re-cone. According to the data sheet they will go to 50Hz in a 14 litre box, 42hz in 22 litres, or 38Hz in 30 litres. All figs are @ -3dB.
If interested I can send a copy of the data sheet.
wich one?
Post Options Post Options   Thanks (0) Thanks(0)   Quote _Natty_ Quote  Post ReplyReply Direct Link To This Post Posted: 20 November 2018 at 8:48am
no way to going under 6.5"so... a 4" is not capable to playing bass?
any suggestion about design?
bass reflex or band bass?
concept-10 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote concept-10 Quote  Post ReplyReply Direct Link To This Post Posted: 20 November 2018 at 7:40am
For a home application these will be very hard to beat, if I was doing another home system I would look no further.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mobiele eenheid Quote  Post ReplyReply Direct Link To This Post Posted: 19 November 2018 at 8:21pm
Second the TangBand W6-1339 or it's ferrite brother, 6.5" with very good price/ performance, bit power hungry though.
boots-hifi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote boots-hifi Quote  Post ReplyReply Direct Link To This Post Posted: 19 November 2018 at 8:18pm
Got a 8" Peerless driver sitting here from sound imports waiting to be loaded into a 60l ported box. Ill let you know what the outcome is.
Meat View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Meat Quote  Post ReplyReply Direct Link To This Post Posted: 19 November 2018 at 7:26pm
Tangband w8-740p is meant to be a monster if it has to be an 8". They also have some quite silly 6.5"s.
Post Options Post Options   Thanks (0) Thanks(0)   Quote markie Quote  Post ReplyReply Direct Link To This Post Posted: 19 November 2018 at 4:45pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote _Natty_ Quote  Post ReplyReply Direct Link To This Post Posted: 19 November 2018 at 4:28pm
I've not experince in project home/little system... 12V powered...
no bigger than 8"
and i thin it will be about 3 way, so we can imagine that xover would be 100hz or something like...
i know from physics that size "matter" when we talk about bass and reproduce it, wich is the best speaker size -keeping in mind that the goal si to going as little as possible and as low as possible- no idea about enclousure yet...could be little reflex or other plan that can give me good sub response... even band pass or horn (i dont think is a good solution)
even if u have some "reference" model it will be nice...
