DB mark DP48II software/control software |
Post Reply | Page 12> |
dlyxover
Old Croc Joined: 14 June 2007 Location: Liverpool Status: Offline Points: 1508 |
Posted: 07 December 2018 at 8:40pm |
SOLUTION
It appears that Windows 10 don't play nice with the USB-serial port in the DB Mark DP48II. Windows 7 Ultimate works with all 3 DB Mark processors I have (DP48II, DP36II and DP26IV) Windows 10 did work with DP36II and DP26IV. Hope my little tech adventure helps other out. Thanks to all for their input.
dlyxover
Im going to try a different version of windows, only use windows for the db mark processor.
Can the firmware be updated?
Guests
Guest |
Perhaps they used a fake prolific serial chip:
kedwardsleisure
Old Croc Joined: 20 January 2009 Location: Staffordshire Status: Offline Points: 4938 |
I've had a similar problem, tried it on an XP computer and worked first time, was the same firmware version as yours too.
North Staffordshire |
dlyxover
Mircea I've installed the driver from your download and the software but still no joy.
I'm beginning to think its a windows 10 software issue or the USB to serial board on the DP48 has failed. In windows device manager, its still got the yellow ! triangle and "This device cannot start. (Code 10) A device which does not exist was specified." in device status. But with the DP36 (which is working) it dose not have warning in device manager.
Mircea Bartic
Old Croc Joined: 18 February 2005 Location: Romania Status: Offline Points: 2581 |
http://www.facebook.com/nexus.acoustics.research Ex Nexus_3 |
Mircea Bartic
I Have an old Driver DVD in my database. It should work with your version. It's uploading to wetransfer as we speak
dlyxover
on the system set up menu
option 6 (system information) its says "speaker processor V4.3.2" can't find anything else. |
bee
Old Croc Joined: 14 June 2011 Location: Middlesex Status: Offline Points: 4553 |
on the unit, go through menu options. device settings..
dlyxover
Where do I find that?
bee
whats the firmware code on the device.
dlyxover
Hi bee
I thought I had but it appears not. Could you point me to the correct ones? In windows the 'prolific usb to serial port' has a error on on DP48 but not the DP36 " This device cannot start. (Code 10) A device which does not exist was specified. " Edited by dlyxover - 05 December 2018 at 8:53pm |
