  New Posts New Posts RSS Feed - yet another laptop noise problem - hdmi
godathunder View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote godathunder Quote  Post ReplyReply Direct Link To This Post Topic: yet another laptop noise problem - hdmi
    Posted: 04 February 2019 at 12:56pm
mutter mutter shite switchmode psu noise crap mutter mutter
my problem is that my laptop is dumping its unwanted noises into my hifi
its the usual problem, fine on battery. fizzes, pops, hums and buzzes with the psu connected - present with all psus tried - disappears if I do the naughty thing with the earth disconnected (put your swords away gentlemen, it was done for test purposes only)
isolation transformers would be lovely but:
my problem is that Im connecting via hdmi
has anyone come across a hdmi isolation solution?
or I may just build a proper heavy metal psu and see if that improves matters
Edited by godathunder - 04 February 2019 at 12:58pm
LOUDER THAN LOUD
Post Options Post Options   Thanks (0) Thanks(0)   Quote toastyghost Quote  Post ReplyReply Direct Link To This Post Posted: 04 February 2019 at 1:00pm
Your laptop is double insulated anyways and doesn’t need an earth. If nobody else is gonna use it then remove away.
Post Options Post Options   Thanks (0) Thanks(0)   Quote godathunder Quote  Post ReplyReply Direct Link To This Post Posted: 04 February 2019 at 1:03pm
point taken but it feels like the wrong solution
Im obviously looking for a way of further complicating my life
LOUDER THAN LOUD
efinque View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote efinque Quote  Post ReplyReply Direct Link To This Post Posted: 04 February 2019 at 1:15pm
At a venue I used to DJ and host karaoke there's a micro-USB to HDMI adapter via an Ethernet/RJ45 from a tablet to the main system which is used for the AV signal (the distance between the tablet and the booth is about 20m)
Sometimes the cable/adapter (which also supplies power to the tablet) gets loose which cuts the signal.
cravings View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cravings Quote  Post ReplyReply Direct Link To This Post Posted: 04 February 2019 at 1:18pm
i'm sure that answers your question.
dylan-penguinmedia View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dylan-penguinmedia Quote  Post ReplyReply Direct Link To This Post Posted: 04 February 2019 at 1:20pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote godathunder Quote  Post ReplyReply Direct Link To This Post Posted: 04 February 2019 at 1:21pm
thank you efinque, thats very kind of you but possibly not entirely pertinent to my problem
LOUDER THAN LOUD
Post Options Post Options   Thanks (0) Thanks(0)   Quote efinque Quote  Post ReplyReply Direct Link To This Post Posted: 04 February 2019 at 1:28pm
External USB/Firewire interface if you're running sound only?
Laptop soundcards are horrible anyway.
Post Options Post Options   Thanks (0) Thanks(0)   Quote godathunder Quote  Post ReplyReply Direct Link To This Post Posted: 04 February 2019 at 1:34pm
audio + video output required hence hdmi
Ive got a couple of those cheap little behringer usb interfaces for 2ch audio needs
LOUDER THAN LOUD
Post Options Post Options   Thanks (0) Thanks(0)   Quote kedwardsleisure Quote  Post ReplyReply Direct Link To This Post Posted: 04 February 2019 at 2:02pm
If the laptop adapter has an earth then it's there for a reason, it's using it to provide the barrier between mains and low voltage output. So don't remove it. A class 1 psu is also allowed to leak alot more current to earth than a class 2 psu and with the earth lifted that leakage is going to present itself on any exposed conductor on or connected to the laptop.
I would look around to see if there's a double insulated power supply option (these used enhanced pri-sec insulation), the sort that uses a figure-8 mains lead. It's no guarantee of being noise free but it's got to be worth a try, I know clients that have had success with it in karaoke with multiple TVs.
I'm sure you can get an HDMI isolator but I bet they're dear.
K. Edwards Electronics Engineers
North Staffordshire
Post Options Post Options   Thanks (0) Thanks(0)   Quote godathunder Quote  Post ReplyReply Direct Link To This Post Posted: 04 February 2019 at 2:24pm
I think a rummage round the spares boxes is in order. Ill see if I can knock up a suitable 19v/70w wirewound psu out of the parts Ive got lying round and some minimal ordering.
will be interesting to see if it provides a solution
Ill add it to the to do list and report back with results at some distant point
LOUDER THAN LOUD
Post Options Post Options   Thanks (0) Thanks(0)   Quote kedwardsleisure Quote  Post ReplyReply Direct Link To This Post Posted: 04 February 2019 at 2:54pm
that's going to be a hell of a linear power supply! It'll need to use a switching regulator to get that sort of current without a heatsink the size of a potato waffle
North Staffordshire
