Weatherproof audio boxes |
Post Reply | Page 12> |
dylan-penguinmedia
Old Croc Joined: 14 April 2011 Location: Brighton Status: Offline Points: 4575 |
Posted: 11 February 2019 at 9:26pm |
You can get IP65 flip front surface boxes that take a single or double standard socket in them.
Get one of those, ditch the plastic socket and add a metal plate with d type punched holes. Job done.
MattStolton
Old Croc Joined: 04 September 2010 Location: Walthamstow Status: Offline Points: 4234 |
Recently did the FBU's fire engine conversion, and stuck some speakon outlets in such a box.
Bought one of the single 13A socket outlet hinged lidded IP66 ones, ripped out the 13A socket, put a metal plate in its place, and punched a 24mm Qmax hole for standard neutrik cut out. Lid with hinge to top, offers in use "roof", and then sealed when unused. Bit of a faff, but worked. Less faff, but not cheap, Off the shelf, Canford, do them - Link |
I-shen Soundboy
Registered User Joined: 21 December 2016 Location: Big Smoke Status: Offline Points: 375 |
Neutrik do sell IP67 rated xlr connectors, in line and panel-mount, which might be nice if it rains while you're using them:
...although I'd be rilly careful about active speakers in the wet. |
Sheggy
Old Croc Joined: 23 May 2008 Location: London Status: Offline Points: 1991 |
Hah! I might just do that. S
godathunder
Old Croc Joined: 19 July 2004 Location: wicklow Status: Offline Points: 1834 |
surely just use the 13a sockets and make up some 13a-xlr cables
I mean, what could possibly go wrong
LOUDER THAN LOUD
chris_k
Young Croc Joined: 14 April 2005 Location: United Kingdom Status: Offline Points: 1258 |
Bg weather proof sockets have removable internals leaving you with a nice lockable ip rated box
Screw fix 15quid Check out big Clive on YouTube. He reviewed one recently
Edited by chris_k - 10 February 2019 at 8:26pm |
wires
Young Croc Joined: 21 May 2009 Status: Offline Points: 1365 |
I’ve used a 13a weatherproof, covered socket before on many occasions for tv points outside, removed the 13a plate and replaced with a single gang coax point (will be similar to a 1 gang xlr plate).
It was a bit of a faff finding the right plate that fits the box due to tight dimensions. You might just be able to close the lid while plugged in you buy angled xlr connectors but again it will be a tight fit.
Sheggy
Yes, I think that's the solution but I'd like the waterproof locking cover that the 13A sockets have. Do you know if you can get bone of these and remove the gubbins? I've never installed one. S
ceharden
The 10,000 Points Club Joined: 05 June 2005 Location: Southampton Status: Offline Points: 11776 |
Simplest solution is just to get a generic IP67 box and some cable glands. Just coil up the end of the cables in the box and put the lid on when you're not using them. I'm assuming you're not trying to make the connections waterproof when in use.
mini-mad
Old Croc Joined: 13 July 2012 Location: london Status: Offline Points: 6903 |
100v line?... a single cable run around the fence hooked up to multiple speakers?
Sheggy
Bluetooth won't work - gardn is too big.
S
mini-mad
...and the reason you can use a bunch of Bluetooth speakers?
