  New Posts New Posts RSS Feed - X1 3D Plans for CNC
X1 3D Plans for CNC
vertx View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote vertx Quote  Post ReplyReply Direct Link To This Post Topic: X1 3D Plans for CNC
    Posted: 05 November 2022 at 12:00pm
I did a few of these in lockdown during covid when I was learning Fusion.
Why 3D? For me the path for cutting designs is now straight from Fusion to CNC.
One of my CNC guys cuts straights from a Fusion file with an add-on that automatically nests and lays out the objects onto specified material.
Other CNC providers use only DXF, which you can pull from this model via creating drawings of each face and exporting as DXF if you wish.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MarjanM Quote  Post ReplyReply Direct Link To This Post Posted: 05 November 2022 at 11:50am
Why the need of 3D drawings? I have made so many boxes and never ever needed anything made in 3D.
Vaso_Bobinata View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Vaso_Bobinata Quote  Post ReplyReply Direct Link To This Post Posted: 05 November 2022 at 8:47am
The  DWG file is not a 2D shematic?  Am i doing something whrong?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Vaso_Bobinata Quote  Post ReplyReply Direct Link To This Post Posted: 05 November 2022 at 8:37am
Great stuff mate. how to export  to cutlist.. i was wondewring.
 Thanks...
Post Options Post Options   Thanks (1) Thanks(1)   Quote vertx Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2019 at 9:37am
A while back when I was learning Fusion 360 I used the 2D plans here to CAD this up. I've shared the file for anyone who might want to get this cut:
The online link lets you download the full 3D file, measure, explode, rotate, etc.
I take no responsibility for any errors in this so might be worth a quick reference/check against the 2D plan before getting it cut!
Edited by vertx - 21 May 2019 at 9:39am
www.instagram.com/translate.sound
