  New Posts New Posts RSS Feed - before starting : 12v or 220v amp ?
suparub View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote suparub Quote  Post ReplyReply Direct Link To This Post Topic: before starting : 12v or 220v amp ?
    Posted: 01 July 2019 at 9:02am
Just to add that I'm more than open to "build the amp" myself as in this video : https://youtu.be/Dit5JPAXwMM ;
Post Options Post Options   Thanks (0) Thanks(0)   Quote suparub Quote  Post ReplyReply Direct Link To This Post Posted: 01 July 2019 at 5:11am
Hi everyone ! Little question as I'm trying to decide on which type of electric amp I should go with. The idea is to use as less as power possible from my batteries and to last as long as possible.
So on, I m not sure if I should go with 12V class D amps or with a 12<>220 inverter + a 220v inuke 4 6000 class D type amp for example. Quality is also an important factor. Here are my drivers :
2 x 900W RMS Subs  (8 Ohms each)
2 x 650W RMS Mids (8 Ohms each)
2 x 150W RMS Tops (8 Ohms each)
Any amp that you would recommend in 12v ? I see a lot of cheap ones of Ebay but quality is very important and Im looking to build something that lasts.
Thanks for the direction !
