  New Posts New Posts RSS Feed - Peavy Hisys XT crossover help.
VECTORDJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote VECTORDJ Quote  Post ReplyReply Direct Link To This Post Topic: Peavy Hisys XT crossover help.
    Posted: 18 February 2021 at 8:10pm
I thought it was RXE035 but poster that says RXE030 may be right. I always thought the value was too low. It must latch and send the power to the bulb as soon as You crank it up. 030 will trip/latch at .60 amps. Any other ideas??
Five & View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Five & Quote  Post ReplyReply Direct Link To This Post Posted: 18 February 2021 at 11:48am
Polyswitch For Peavey Soundguard HF Protection Circuit
Part # Rxe030 (X030)
Let The Music Play
Shortrope View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Shortrope Quote  Post ReplyReply Direct Link To This Post Posted: 14 August 2019 at 6:52pm
Originally posted by tomr_29 tomr_29 wrote:
Yeah this is a polyfuse. I’ve replaced a few on a number of Peavey Hisys crossovers. Typically have used a 250mA and actually still have a few left. The part number on the pack is 647-8443 (RS components part number).
Legend! Thanks a million!
My Tinnitus is coming along nicely!!
tomr_29 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tomr_29 Quote  Post ReplyReply Direct Link To This Post Posted: 14 August 2019 at 5:59pm
Proper capitalisation is the difference between helping your Uncle Jack off a horse and helping your uncle jack off a horse.
www.facebook.com/tremoracoustics
studio45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote studio45 Quote  Post ReplyReply Direct Link To This Post Posted: 14 August 2019 at 2:28pm
Again, at that size, it could only be a few hundred pF at most - so not gonna be doing much filtering in a low-impedance circuit....
I also see what looks like a dry joint at the bottom centre of the board (dark ring all the way around the component leg)
If you can sketch out a schematic, and the mystery component is indeed in series with the HF and in parallel with that light bulb, then it's a classic Polyfuse protection circuit. When the Pfuse opens, all the current has to flow through the bulb, which will drop the excess power, and then blow itself if you're really silly or your amp is oscillating. In which case, I would try replacing with a 500mA Pfuse and see if that works.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Shortrope Quote  Post ReplyReply Direct Link To This Post Posted: 14 August 2019 at 2:18pm
Originally posted by studio45 studio45 wrote:
Perhaps more likey to be a Polyfuse rather than a thermistor? A thermistor that small wouldn't really have a place in a high powered crossover circuit, whereas a 1 amp Polyfuse is about that size and would offer useful protection to the HF driver, if it's in series?
Yeah you're right I don't think it's Thermistor now either.
I was wondering if it's a Ceramic Capacitor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote studio45 Quote  Post ReplyReply Direct Link To This Post Posted: 14 August 2019 at 2:15pm
cravings View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cravings Quote  Post ReplyReply Direct Link To This Post Posted: 14 August 2019 at 12:34pm
he could take a photo of it.. it probably says something on it..
Post Options Post Options   Thanks (0) Thanks(0)   Quote Shortrope Quote  Post ReplyReply Direct Link To This Post Posted: 14 August 2019 at 11:54am
does he have a second one the same?
Urrgh!...Face+Palm...I didn't think of that!
It's a 40min drive away and I was there yesterday. Disapprove
Post Options Post Options   Thanks (0) Thanks(0)   Quote cravings Quote  Post ReplyReply Direct Link To This Post Posted: 14 August 2019 at 11:48am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Shortrope Quote  Post ReplyReply Direct Link To This Post Posted: 14 August 2019 at 11:26am
This is a long shot but I’m trying to do a favour for a pal and repair his old Peavey crossover.
I need to find the spec for this Thermistor.
