  New Posts New Posts RSS Feed - Help on diameter.
Help on diameter.
BBHF View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BBHF Quote  Post ReplyReply Direct Link To This Post Topic: Help on diameter.
    Posted: 24 August 2019 at 2:50pm
Hi MT conoisseurs.
I'm updating from 4 to 6x MT121 but my boxes are PDN.12MH25 loaded. These drivers are not in stock nowhere...
So, I'm thinking on changing drivers.
Option 1. PD123
Option 2. Other brands...
Do you know what brands can fit on PD's Bole holes? MTs have the female bole in the closed part of the box so can't do new holes.
Give thanks.
(Sorry for my english)
njw View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote njw Quote  Post ReplyReply Direct Link To This Post Posted: 24 August 2019 at 8:09pm
If you use threaded inserts which fit on the driver side of the baffle you can then fit whatever drivers you want, that said,  I would be tempted to just use pd121's in the new pair of cabs as they're a very good horn driver and shouldn't sound a million miles away from the PDN.12MH25'S you already have.
This page was generated in 0.090 seconds.
