Mixer as pre amp using only 1 crossover |
bob4
Old Croc Joined: 29 February 2004 Location: Finland/Germany Status: Offline Points: 1843 |
Posted: 14 January 2020 at 11:49am |
Read the manual, and have a good look at the block diagram of your mixer until you understand it. For the turntable you need a standalone RIAA preamp.
LikkleBat
New Member Joined: 13 January 2020 Status: Offline Points: 7 |
Ik tested this with a Mic and the faders do affect the direct outs.
dj jammin
Young Croc Joined: 10 April 2010 Location: southampton Status: Offline Points: 770 |
Also sorry to say.. the direct outs will not be affected by the channel faders.. bit more working out required.. sometimes the best way to start is to draw a simple diagram of what you want to achieve.. good luck
Reverence Sound system
monkeypuzzle
Young Croc Joined: 25 January 2005 Status: Offline Points: 924 |
A headphone amp won’t give the required RIAA eq curve for vinyl so you’ll need to factor this into the mix.
JBK
Registered User Joined: 03 March 2016 Location: Besançon Status: Offline Points: 263 |
Lots of information here : https://forum.speakerplans.com/gear-that-substitutes-a-reggae-preamp_topic94395.html |
LikkleBat
Hello,
I recently got a Behringer xenyx 2442fx mixer and I can either use it or sell it. But I am thinking to use it to try something. I want to use it as pre amp. I figured out I can connect my turntable to my crossover (4way) (using a headphone amplifier, so the option of also connecting a cd player remains), then I would run each output to a line in from the mixer and go from the direct out's to the amps. This way I can operate the gain of each frequencyband with the faders of the mixer. Each channel also has a mute, this way it can operate as a 'kill'. This would work I guess. The only thing that remains is how to safely(!) connect a mic, delay, siren,... on this setup. Anyone got experience with this? I am not sure what to use for this to work. The aux sends and returns or would it be better to work with the subgroups (as this opens more options I think). Currently breaking my head on this. I can't try it yet, because I am missing some cables. Thanks in advance! |
