  New Posts New Posts RSS Feed - X1 tuned for 65-120hz?
freddyi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote freddyi Quote  Post ReplyReply Direct Link To This Post Topic: X1 tuned for 65-120hz?
    Posted: 06 December 2004 at 6:44pm
Hi Martin - yeah (~same) - looks easier to  load/unload driver
Timber_MG View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Timber_MG Quote  Post ReplyReply Direct Link To This Post Posted: 06 December 2004 at 6:34pm
Exactly the same horn in theory, just re-worked to have a 60x60 front. V-throat as you thought (they have soem very nice CAD-drawings for these if you can hack through teh Duthc on speakerstore.nl)
Post Options Post Options   Thanks (0) Thanks(0)   Quote freddyi Quote  Post ReplyReply Direct Link To This Post Posted: 06 December 2004 at 2:02pm
wonder how the throat would perform in version which appears to have cone parallel to a panel and firing "against"  that  panel? - is this a non-issue in sub?  - don't see view of initial throat section - but assume "V" ramps
how much would this version lower cutoff vs original Punisher?
Post Options Post Options   Thanks (0) Thanks(0)   Quote mobiele eenheid Quote  Post ReplyReply Direct Link To This Post Posted: 06 December 2004 at 11:38am
6th order bandpass cabs don't need to be that big for 65-120 Hz, so why bother? You could make something half the size of an X1 and still have plenty of output to go nicely with an X1.
On a Dutch forum someone is working on a Punisher that is 2' x 2' from the front, so it's made for standard trucksizes. Tho 2" deeper, it would fit pretty good, also when it comes to output.
http://www.licht-geluid.nl/forum/topic.asp?TOPIC_ID=12309
Cheers
Hobbyist2004 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hobbyist2004 Quote  Post ReplyReply Direct Link To This Post Posted: 06 December 2004 at 5:03am
If you wanted to stack an X1 on top of another, could you keep the bottom X1 normal for 32-65hz and re-work the top X1 (ports) to cover 65-120hz? This would be one way to have the same size cabs cover 32-120hz.
