  New Posts New Posts RSS Feed - MS-18 mk2 or mk3 for Fane XB?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dub Specialist Sound Quote  Post ReplyReply Direct Link To This Post Topic: MS-18 mk2 or mk3 for Fane XB?
    Posted: 12 February 2020 at 10:56am
tbh yes brother, m3 better cone controll...
but tbh ive built all 3 of them boxs...all have a good bass output...
good luck building...
sarsen1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sarsen1 Quote  Post ReplyReply Direct Link To This Post Posted: 12 February 2020 at 9:18am
Thanks for this, perhaps I just go for mk3, build one and see if I like it... Will be mainly used for listening to roots stuff so nothings crazy low, but would also like it to be a versatile enough box to do gigs with other types of music.
Cheers!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dub Specialist Sound Quote  Post ReplyReply Direct Link To This Post Posted: 11 February 2020 at 7:07pm
Dont worry about wat you  read bro, xb in small chambers have been used for donkeys years, regaedles what any ones says....xb will work in small medium  large medium.....depends on what sub/bass bass notes wanted and cone controll..beware...
Post Options Post Options   Thanks (0) Thanks(0)   Quote sarsen1 Quote  Post ReplyReply Direct Link To This Post Posted: 11 February 2020 at 11:09am
Having just built my first reflex sub, I am now looking to build something     more scoop-like.
I know this has been covered before, but after much trawling through the various MS-18 threads on here, it seems there are conflicting opinions as to whether the Fane XB would be suited to the smaller chamber of the MK3 or the larger chamber of the MK2.
I was leaning toward MK2 and then adding the extra panel to make it MK3 if the driver didn't look controlled but if someone could point me in the right direction first that would be great!
Edited by sarsen1 - 11 February 2020 at 3:06pm
