  New Posts New Posts RSS Feed - Double 10" Sealed Enclosure Advice please
 Post Reply Post Reply Page  123 12>
Sonic the hedge View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sonic the hedge Quote  Post ReplyReply Direct Link To This Post Topic: Double 10" Sealed Enclosure Advice please
    Posted: 24 May 2020 at 11:04am
Originally posted by Jack1991 Jack1991 wrote:
Thats a good idea actually using a aux bluetooth adapter. It will stop me accidently pulling the aux out my phone then. And also save some space in my 'amp/cables box' by getting rid of my long aux lead.
I assume your bluetooth aux adapter is battery powered?
The one I have has mini usb for power, so you can use a phone charger or usb battery pack. I guess you could also use a car usb charger for 12v battery feed, but you might need to try a couple of different types because some chargers interfere with the audio.
Took ages for delivery so perhaps find a different seller! But this model works perfectly, I've had a couple different types and some are a bit temperamental, Bluetooth drops, noise etc.
Edited by Sonic the hedge - 24 May 2020 at 11:32am
Jack1991 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jack1991 Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2020 at 8:41am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sonic the hedge Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2020 at 8:14am
Oh ok cool thanks Sonic! It seems to work really well this app.
Thinking about it booster app probably won't drain the battery much using an aux lead because the input impedance to an amp is much higher than wired headphones etc. but definitely chews the battery using the phone speaker.
For home I use a Bluetooth aux adapter, tenner off eBay and sounds perfect.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jack1991 Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2020 at 7:05am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sonic the hedge Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2020 at 2:04pm
i have a 'Equaliser FX Pro' app on my phone which i have to use when i plug my phone in via aux as for some reason the volume goes really low when on aux. Anyway, it has a volume booster which i turn on and then also i adjust all the EQ through there, which seems to work really well
Phones usually have a software cap on aux volume to stop you from damaging your hearing using headphones too loud. The EQ/volume boost apps just override the level cap in the phone software. Does the trick but it does drain the phone battery quicker too.
Edited by Sonic the hedge - 23 May 2020 at 2:05pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jack1991 Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2020 at 1:38pm
Perfect thanks mate! ๐Ÿ˜€๐Ÿ‘๐Ÿผ
DMorison View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMorison Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2020 at 1:30pm
The only thing that really affects battery life is how loud you have it playing.
All of the other adjustments you are talking about are just ways of getting to that final output.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jack1991 Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2020 at 3:17pm
Cool okay thanks very much again for all your help!
I will be getting it all out soon for a first test in the garden. Its only been tested in my garage so far but it really exceeded my expectations indoors. The true test is outdoors i think though. Thought id best wait for a friday to test it in the garden as neighbours probably wouldnt be too pleased midweek haha ๐Ÿ˜‚
Also last question, i have a 'Equaliser FX Pro' app on my phone which i have to use when i plug my phone in via aux as for some reason the volume goes really low when on aux. Anyway, it has a volume booster which i turn on and then also i adjust all the EQ through there, which seems to work really well. I assume this also wont have any significant effect on the power draw as now it seems like its also kind of similar to the amps gain knob. Or am i very wrong?
Edited by Jack1991 - 22 May 2020 at 3:26pm
Peter Jan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Peter Jan Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2020 at 3:08pm
And obviously the higher its set the harder the amp has to work. So a higher input could then have the gain set lower reducing how hard the amp has to work. Correct?
No not exactly... as he said itโ€™s just a (passive) voltage divider, not a real gain and even if it was, at that point were talking low voltages with relative high impedances or a very low power difference in whatever the position of the โ€œGainโ€ would be. Even if it was a true gain (which it is not), it would still be very, very, very marginal in terms of power consumption or battery drain.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jack1991 Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2020 at 3:03pm
Oh right i see, i thought the gain would effect the power drain.
Right im starting to get it now then. Thanks again!
So for the battery to last longer then, i would be best off using a low voltage input like a phone. Instead of say decks or something more powerful.
Edited by Jack1991 - 22 May 2020 at 3:04pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Peter Jan Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2020 at 3:01pm
So theres no harm having it set too low. Just going too high could create distortion or clipping depending on input voltage. Correct?
Correct
Post Options Post Options   Thanks (0) Thanks(0)   Quote Peter Jan Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2020 at 2:58pm
....So i assume obviously the higher the gain the harder the amp is working which in turn reduces the battery quicker. Realistically though do you think it would be much difference in battery drain?
The battery drain will be proportional to the effective power put out by the amp, not the position of the gain/sensitivity/level pot. You can have the gain on the amp all the way down and have a source putting out say 5V or so, than the amp will drain the battery substantially, because it it close to maximum power.
With the gain on the amp all the way up, but a source barely touching 0,1V output, youโ€™re not even at half power. Itโ€™s all relative ๐Ÿ˜‰.
