Yamaha s115h 2. 400 watt 8 ohm speakers |
Foyle1
New Member Joined: 27 May 2020 Location: Syracuse, indi Status: Offline Points: 3 |
Posted: 27 May 2020 at 5:29pm |
Hello thanks. But my other speakers work fine on same leads
djeddie
Old Croc Joined: 26 April 2004 Location: Bristol Status: Offline Points: 4125 |
Check your leads first... if one worked, and now bot don't, I'd guess there may be a problem there. It may even be the connectors on the amp/speaker/crossover/source etc etc.
Foyle1
Anyone tell me how to trouble shoot what’s wrong? I have two speakers one quit. Are used an ohmmeter and it seems that all the readings were the same as the speaker that work? I think it’s a crossover but I don’t have sound out of either speaker now. And can someone tell me where to get parts or what parts it might need if it is the crossover? What kind of ohm Readings should I have on different parts? Are the speakers worth fixing? I think I need bigger speakers but I would like to get these working anyway. Thank you for your replies
