X1 in for a refurb. |
Author | ||
FOO ![]() Registered User ![]() ![]() Joined: 23 December 2018 Location: Denmark Status: Offline Points: 470 |
![]() ![]() ![]() ![]() ![]() Posted: 10 July 2020 at 5:35pm |
Okay
csg ![]() Old Croc ![]() Joined: 17 September 2007 Location: bedford Status: Offline Points: 5744 |
Yes. Easily.
Tried to convince the owner, but he want handles. Fair enough then :)
Will a JBL SRX725 dual 15" fullrange box be able to handle two X1 underneath? A stack each side powered by a rack with Crown MA 1200 and 2x MA5000.
Digbethdave ![]() Registered User ![]() ![]() Joined: 16 November 2018 Status: Offline Points: 388 |
If its on castors, even with full grill, it's easy enough to move and stack without handles.
I just had a hit in the search. I call it wadding, but others call it lining.
That made a difference :) So wadding in the chamber :)
edboom ![]() Registered User ![]() Joined: 13 May 2011 Location: manchester Status: Offline Points: 47 |
In the construction guide, Rog puts wadding on some of the inside cab walls. It's not exactly the same cab, but it's very very similar.
As far as i can see, they are made to original plans.
Regarding handles, they are needed. They got fullface grills, so a bit difficult to grab the ports :( I just checked the original plans. No wadding. But i have seen a plan on another site where wadding is added. I will stick with the original then.
If they are to original plan, I'd just put castors on the back. The ports are good enough handles for getting them onto wheels. And also for stacking them up.
Half the time handles are never in the right place. I believe the original plans had no wadding
So.... I got my hands on four Void V18 for these X1 and loaded them.
But one question comes to mind.. shouldnt there be damping material on the inside of the front panel and in the inside corner of the front chamber?
Guess its good then. Thank you for the tip :)
Yes. Countless pro manufacturers use them or similar.
Why dont they make sense? Because they only Work in one way ?
Are those bowls stiff enough to deal with the pressure inside a box like this?
