What's better? |
Post Reply | Page 12> |
bass*en*mass
Old Croc Joined: 03 September 2009 Location: "unknown" Status: Offline Points: 4009 |
Posted: 24 August 2020 at 8:56pm |
yup.. but if your "subs"already peak at 45ish hz (scoops) you surely wont want another boost at 50ish hz, do you? unless its an spl drag race gig/clash but actual listening to music and its notes ;) OP, if you need/looking for dedicated kicks, its either the cubo kick or front loaded horns in my books tbh., Marc Os flh plans on hornplans.fr do work well too, just make sure you use 4 per side ideally and get them close to your tops.. :) |
Cheekybox
Registered User Joined: 04 October 2014 Location: Smoke Status: Offline Points: 104 |
Would you overlap the points? Cheers |
Sypa
Young Croc Joined: 21 February 2013 Location: Croatia Status: Offline Points: 921 |
Thanks(1)
+1 for the cubo kick .
A stack od es18 over a stack od subs tho can help a bunch with 50-60hz impact if aligned correctly.
Cheekybox
Dedicated kick. 70 or 80 to 170/80
bass*en*mass
beats both at what? ..you still didnt tell us what exactly you are looking for.. :( dedicated kick, allround/compromised bass, bit of both etc. etc. - spill the beans :) es18s do go lower than the hd15s (45ish hz in multiples compared to 60ish hz) es18s do not go higher pleasently than hd15s (both struggle above 160ish hz, no matter what driver imo and experience) cubo kicks are dedicated kicks and sound best 80-160ish.. (better than those 2 above imo) |
Cheekybox
Really? That is very interesting to hear. I thought i'd read somewhere that the ES18 beats both but i could be wrong about that.
My sense was that over the years that people were moving away from HDs as new designs come out. Is it the opinion of many people, then, that this is a mistake or at least unnecessary?
concept-10
Young Croc Joined: 17 May 2016 Status: Offline Points: 1293 |
Agreed, Cubo kick is much better sounding than the HD15 or the ES18. |
bass*en*mass
Cubo Kick is another option imo, sounds WAY better/smoother than HD15s! ES18 suffers the same issues (Honk) if not carefully controllered via DSP, just goes a tad lower due to size. What exactly are your needs? Plenty of options but as usual all have pros and cons :)
Digbethdave
Registered User Joined: 16 November 2018 Status: Offline Points: 406 |
You seem happy with the HD, don't really see the reason to change. |
Cheekybox
im thinking of replacing all my HDs with ES18s. Worth it?
Digbethdave
The best thing about the HD, is that it's small and light. And yes you can use it on its own with a couple of small tops. For its size vs donk output I don't think you can beat them tbf. F2B is a nice box, but you'd want to have a stack of them, maybe with some bsx/218 for lower extension. It's wasted as a 'kick bin'
bass*en*mass
timebombs rb212 is similar to the f2b, folded frontloaded horn - much nicer to my ears than a bph..
