  New Posts New Posts RSS Feed - 15" bass box - with a difference ...
JonB67 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JonB67 Quote  Post ReplyReply Direct Link To This Post Topic: 15" bass box - with a difference ...
    Posted: 24 January 2021 at 6:28pm
If it works well enough to make rabbet joints, that would help you fix them together a lot.
Edited by JonB67 - 24 January 2021 at 6:41pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote JonB67 Quote  Post ReplyReply Direct Link To This Post Posted: 24 January 2021 at 6:27pm
Id also try cutting it with a router. A sharp bit should leave you a nice clean cut. Just cut it about 5 mm away with something else, jigsaw or grinder then tidy to finish dimensions with the router
Post Options Post Options   Thanks (0) Thanks(0)   Quote JonB67 Quote  Post ReplyReply Direct Link To This Post Posted: 24 January 2021 at 12:08pm
Id be trying to take advantage of the face material being basically grp epoxy.
Id use a thick epoxy to bond (basically glue) the 90 degree edges and let it set. Id then us glassfibre reinforcing tape (like chopmat but on rolls) and do the internal corners.
Should then be strong enough that all you need on the outside is a cosmetic capping.
Just make sure you key and prep the faces well and it should be really strong.
Fsurfer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fsurfer Quote  Post ReplyReply Direct Link To This Post Posted: 24 January 2021 at 8:59am
Lovely finish
doober View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote doober Quote  Post ReplyReply Direct Link To This Post Posted: 10 January 2021 at 5:00pm
That's great thanks.
Blahblahblah
slaz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote slaz Quote  Post ReplyReply Direct Link To This Post Posted: 08 January 2021 at 1:02am
Originally posted by doober doober wrote:
A friend of mine collects old Tannoy stuff, he was actually looking for plans to make a Tannoy bandpass type cab. Would you be able to post some pics when you see the box? It might be just what he's after.
Thanks
Well I want to have a look at this box myself first obviously - figure out how to get inside it and check out the driver. Apparently someone has made a bit of a mess of the input panel (prob trying to connect it to a hi-fi amplifier or some such), so might need some attention.
For sure I'll post up some pics - the whole thing might be up for grabs - not sure yet.
slaz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote slaz Quote  Post ReplyReply Direct Link To This Post Posted: 08 January 2021 at 12:25am
Thanks for the input guys ...
Well I got around to digging up the HC stuff from the shed ... and it seems my memory of what I have is a bit screwed up ..... I don't have a complete 8 x 4 sheet of HC. but I have 2 pieces :-
hexalite 14mm thickness
1) 38" x 41.5" 965mm x 1055mm - few small holes (weighs 3.3Kg)
2) 34" x 52"   863mm x 1320mm - covered with material/foam underneath + timber edging.
Altogether thats about 1.5 sheets :-)  .... but may not be optimal in terms of making a cut sheet.
Should be plenty to make a compact 15" box though.
The 1st piece with holes - the holes can be easily gummed up with something (the holes don't go right through - just one layer of the GF).
The 2nd piece needs a bit of attention re removing the material covering, foam and timber edging, but should be in good nick apart from a few holes like above.
I'm pleased with the weight - its about 30% of the weight of 18mm birch ply I think. My proposed 5-sided box should come in at about 5Kg I think - but thats without front baffle, bracing, grill etc.
I've been using this beyma plan (with cut list) as an example/rough guide for size/shape etc.
I'd use cylindrical port(s) (plumbers plastic pipe - 50mm or so ? )instead of the triangular ones.
I'd likely bleat for help a bit with WinISD/box tuning etc. .... some TS params I don't understand properly.
The B&C 15CL76 looks like a little honey for this - thanks for that heads up - and yes of course you're right about using neo .... was hoping to get the driver for <100 quid - but not _too_ expensive.
I'm guessing these are probably meant for stage wedges etc. - so likely designed as bass/mid really rather than specific bass, but should work well for about 40Hz-80Hz or so ... no ?
Actually, my FBT Maxx4 uses B&C neo drivers - so thats kinda nice and neat :-)
I'll almost certainly come back for tips on type(s) of glue/epoxy etc. and stuff like order of assembly of the panels.
Got a bit more of a clue (I think) on how to deal with the edges. Will come back with my proposed details and sketches etc. .... but this ain't gonna be a next week type of schedule ... I'll probably be relying on a mate over the road for tools etc., but ATM he's very covid wary so can't do anything for a while anyway. Can't use the box till summer time anyway, so now is the time to start planning it.
Edited by slaz - 08 January 2021 at 12:29am
Post Options Post Options   Thanks (0) Thanks(0)   Quote doober Quote  Post ReplyReply Direct Link To This Post Posted: 06 January 2021 at 7:33pm
Originally posted by slaz slaz wrote:
I've actually been offered (FOC) an oldish Tannoy 15" bass box of some sort - haven't seen it yet. Suspect it might be a bandpass box from the description. But of course its made from ply or MDF (might be from an install) - and I stand feck-all chance of safely getting that up/down the stairs. The driver might well be decent though ....
Thanks
Blahblahblah
infrasound View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote infrasound Quote  Post ReplyReply Direct Link To This Post Posted: 06 January 2021 at 10:41am
Thanks Smile
JBK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JBK Quote  Post ReplyReply Direct Link To This Post Posted: 06 January 2021 at 10:35am
https://www.facebook.com/rootikalvibeshifi
http://jbkaudio.fr
https://www.youtube.com/playlist?list=PLKB8xPHqsVywM2EgtOaMjdgfIUf_-kFdV
Post Options Post Options   Thanks (0) Thanks(0)   Quote infrasound Quote  Post ReplyReply Direct Link To This Post Posted: 06 January 2021 at 10:26am
Rivets have really poor pullout in these, unless you have the "proper" inserts (hella expensive, and AFAIK only suitable for thicker Aluminium skins)
Alongside a suitable epoxy. I can't remember which we used, but it was 3m and really not cheap. I'm sure RS do a slightly more reasonable equivalent. It could be worth getting one with gap set glass beads (~150um) if the 90 degree angle doesn't support this by geometry. Also, primer if needed and clean the joints properly with IPA and very fine grit before even thinking of gluing.
Bear in mind you have to have continuous adhesion along the full length of both sides (inside and out). Not following this will just result in the composite tearing itself apart quickly. Your edges need to be completely rigid in every plane.
Another alternative is to use two 90 degree aluminium angles inside and out. Getting the correct single extrusion (as linked above) is a bit of a challenge in itself.. Rivets can be used but purely to help keep in position during cure. They must be within the glued area to prevent point loads.
Bracing, you can use the same composite, but at 90 degrees.
Baffle wise, you can use the same material, but have a tapped ring (ideal for load spread) or separate nuts with washers for the woofer bolts. Unless you want to swap woofers about, no reason to have MDF (ugh)
The alu ones have very poor damping, don't know about GF. It could be worth adding some small squares of bitumen to the centre of the panels to see if it makes a difference. This can be done to the outside, and will of course start to weigh quite a bit. Hopefully they will made naff all difference.
Oh, and go Neo if you're making this. Worth extending the weight savings if you're using such a fancy material. I'm a big fan of the B&C Neo drivers and the CL series are hilariously light (and cheap!), with really respectable BL/QTS.
Good luck! A bit jealous that you have such a big sheet of it, it's lovely that it's only half the weight!
Edited by infrasound - 06 January 2021 at 10:28am
imageoven View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote imageoven Quote  Post ReplyReply Direct Link To This Post Posted: 06 January 2021 at 9:39am
Interesting design challenge 👍🤔
Would a rivet into the outer skin be viable?
I imagine a silicone sealant (or similar PU etc) is going to be needed to seal the edges so could be used for construction too. Sikaflex 512 is used widely in the motorhome industry for bonding Ali. It is expensive though and people report good results from cheaper alternatives
Ali extrusion for the corners?
Some flightcase profile s may be big enough and could help with making a removable baffle
