  New Posts New Posts RSS Feed - Can I power 2 kicks and 2 subs with a single amp
njw View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote njw Quote  Post ReplyReply Direct Link To This Post Topic: Can I power 2 kicks and 2 subs with a single amp
    Posted: 27 February 2021 at 11:22pm
Originally posted by citizensc citizensc wrote:
To my understanding an asymmetrical load is no problem at all, it will likely make the power supply's life easier.
 ^^This, where possible I won't have dedicated amps for each frequency band, instead I'll run the same type of amp on kicks and sub and have one channel doing sub and the other kick and then do the same with the mid/top amps with one channel on mids and the other on top, I've done things this way for years and it gives a much cleaner and punchier sound to my ears.
DMorison View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMorison Quote  Post ReplyReply Direct Link To This Post Posted: 23 February 2021 at 1:49pm
As long as the combined load of each pair of boxes is higher than the minimum load each amp channel can drive, then it will be fine.
However, if the amp is only rated to 4 ohms, don't pair up two 4 ohm boxes per channel as that would be a nominal 2 ohm load and make the amp give up its magic smoke.
citizensc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote citizensc Quote  Post ReplyReply Direct Link To This Post Posted: 22 February 2021 at 10:45pm
imageoven View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote imageoven Quote  Post ReplyReply Direct Link To This Post Posted: 22 February 2021 at 10:14pm
Yes.
shashnatiq View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote shashnatiq Quote  Post ReplyReply Direct Link To This Post Posted: 22 February 2021 at 9:06pm
Can I power 2 kicks and 2 subs with a single 2 channel amp?
Wired in parallel, subs on one channel and kicks on the other.
