Vent too long for enclosure |
Post Reply | Page 123> |
studio45
Old Croc Joined: 16 October 2007 Location: United Kingdom Status: Offline Points: 3863 |
Posted: 12 April 2021 at 2:34pm |
Group delay is one of the things that defines the "feel" of a subwoofer or bass driver's output. In general, a sub with lower group delay will be reviewed using terms like "tighter", "dryer", "accurate" and so on, whereas one with higher group delay will elicit responses like "warm", "full", or "rounded". HOWEVER these are obviously very subjective terms and in fact the room the subwoofer is placed in, and its position within that room, can have a MUCH larger effect on its perceived sound. And, GD has nothing in particular to do with the actual output achievable. A very high or very low GD box could be just as loud.
The only mistake to avoid is to have a *large* narrow spike in group delay, such as might be caused by a port tuned for excessive gain in a small box, or application of too much bass boost EQ. I like to tune boxes to have the flattest GD curve I can get, while retaining as much low end extension as possible. Not necessarily the lowest possible GD figures, but the *least change* across the frequencies below 250Hz.
DMorison
Old Croc Joined: 14 March 2007 Location: Aberdeen Status: Offline Points: 1647 |
The method used in that example to create -ve GD would not work for a subwoofer as it relies on a notch filter, which would have to be positioned at the frequency of maximum GD.
This of course would result in you notching out content that you want to keep, right around the low frequency corner of your system. FWIW, David.
ssbb1fire
Registered User Joined: 13 March 2021 Status: Offline Points: 46 |
I agree with everything you said.
I'm looking for explanation on this : https://circuitcellar.com/research-design-hub/group-delay-basics-more-filter-fun/ It's a very complete document, where negative group delay though filters is mentioned. I don't know if that can help me or anyone can explain it in simpler words, because I d'ont understand everything, and that could be very interesting ! |
DMorison
I have seen a rule of thumb that GD(ms) > 400/f is likely to be audible, but I don't know if that is based on solid science or not, sorry.
Things that you can do to improve it: If a ported system, reduce the tuning frequency. If using a high pass filter, reduce its frequency and order. If using EQ to shape the low frequency corner of the system's response, make sure you don't try to make that corner too sharp. Note that several of these have other consequences you may not want. HTH, David.
ssbb1fire
Excuse me, but working on loudspeaker has raised some question and when I was talking about the frequency response and group delay you said :
I'm wondering, is there a way to lower the group delay of a loudspeaker or loudspeaker system ? There's information here and there, but I can't fin an acceptable group delay reference (like 20 hz => 30 ms is ok, 30 Hz => x ms, etc...) and I don't know if there's something I can do about group delay after the loudspeaker is build, by some signal processing... (tell me if I'm not clear) In short : group delay too big filter goes beep beep boop boop less group delay tl,dr : happy |
ssbb1fire
Thank you guys.
I have no problem with it being too big, I just thought that with a 5" driver it would line up perfectly, and a 4" driver wouldn't line up. If I can just go with it, so I will. I just need to figure out how to set it efficiently now. |
smitske96
Young Croc Joined: 16 February 2016 Location: The Netherlands Status: Offline Points: 1085 |
Thanks(1)
You could also fill up the remaining space with some material. However, I would test first before doing that permanently.
BJtheDJ
Young Croc Joined: 28 November 2012 Location: Bristol Status: Offline Points: 884 |
Thanks(1)
It will do the job for you and is most likely only slightly larger than that for a 4". It will take up slightly more volume, but will do exactly the same job. |
then you know that you're not a Millenial kid.</f |
ssbb1fire
I found this but it's for 5" and my driver is 4" so I d'ont know if that's the best choice.
https://www.toutlehautparleur.com/charge-close-0-8l-pour-haut-parleur-13-cm.html |
DMorison
If you can't get a dedicated enclosure like Earplug suggested, just build a box within the main speaker box. Loads of examples in DIY projects all over the web, here's a good one to show what I mean: http://www.troelsgravesen.dk/Discovery-3WC-mkII.htm
ssbb1fire
Thank you for that reminder about volume, I completely forgot.
ssbb1fire
Oh my that's a great solution !
I just have to find it in a store wich delivers to France lol, I might pay up to 100$ in fees from the USA... |
