  New Posts New Posts RSS Feed - Limmer P3,limmer 042
Foca_Dacian View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Foca_Dacian Quote  Post ReplyReply Direct Link To This Post Topic: Limmer P3,limmer 042
    Posted: 15 May 2021 at 1:29am
Hi,
Has anyone build limmer P3?
I have allready got the limmer 042 and drivers for mid high(PHL1040 and DE250),but I am not sure about the low section(085 flare and 15NW76)
P3 is a bit on the heavy side,there is no way of using it on a stand.only flown on a truss or ground stacked.
I have a few options: one is original P3, second is building a cab similar to KV2 ES1.0(folded 12 inch horn for lows),option number 3 is dual 12 inch in reflex.
Subs I use are MTL46, 4 pcs.
What would be the best option?
