New rig plan ❓ |
Beau23
New Member Joined: 06 June 2021 Location: Bristol Status: Offline Points: 7 |
Posted: 10 June 2021 at 4:17pm |
Wow really detailed plan, doesnt look too complicated either, athough i dont have router thing for getting curved edges as i saw in your build, but if its an important part i can borrow one of someone.
i found this mid PARAFLEX 2x12" i think. do you know anywhere i could get a better plan for it or just make a more detailed one myself? http://www.facebook.com/photo/?fbid=3047934118605964&set=pcb.3601198009895300 - http://www.facebook.com/photo/?fbid=3047934118605964&set=pcb.3601198009895300 nice one
Edited by Beau23 - 10 June 2021 at 4:19pm |
Semtek_soundsystem
Registered User Joined: 24 February 2016 Status: Offline Points: 11 |
B&q do 18mm 13lam birch ply "8x4" for 50 quid last time I went, they also have panel saws,
Noud
Registered User Joined: 17 August 2014 Location: holland Status: Offline Points: 66 |
Beau23
yo Noud,
just joined the facebook group looks really good, couldn't find any designs for the Alton 15s though. also looked at the end of your forum n dammm sexy speaker what wattage is the driver your using? and the scoop design i was looking at looks much smaller 800mm by600 by 650. is there a design i could have a look at?
KDW32
Young Croc Joined: 09 April 2010 Location: Green Hell Status: Offline Points: 539 |
you could also try Robbins timber in Bristol Ashton Vale I and friends have used the quite a few times in the Past as their ply was suitable marine Baltic birch void free. Not sure wicks sell ply that's suitable for speaker box building last time I went on wicks most of wood was warped from being badly stored properly. If this has changed im sure someone will correct me.
Edited by KDW32 - 08 June 2021 at 7:52pm |
Beau23
Hi jon,
Ye it pretty much identical scoop but all dimentions abit smaller, id be up for using 18" only thing is the price and that id have to build bigger boxes which again is limited by the price of wood. Based in bristol spoken to Sydenhams n their prices are massive like 70£ a sheet if im buying 4-6 so considering just using a wicks but theres are 40£ a sheet and abit smaller. deffinatly interested if youve got any good sales
sarsen1
Registered User Joined: 01 January 2016 Location: Bristol Status: Offline Points: 114 |
If you are Bristol based as it says on your profile then I would try Avon Plywood, now bought out by Sydenhams. They have bb grade birch, will cut your panels to size and label them. I have used them and found the prices to be decent and the cuts very accurate. Also have a handy online uploader for dimensions.
Your choice of speaker design should be informed by the sort of music you will be mainly using them for, what type of indoor/outdoor venues, audience size and any transport/storage limitations you might have. So if you can provide some detail on that then people might be able to help guide you to some choices suited to you. |
Noud
I would like to suggest to check the high order quarter wave society on Facebook.
They have sub kick and top plans.
I build the Altcon 15s to replace my superscoops. The result were outstanding and highly recommend them! On the end of my topic you will find some info. |
JonB67
Young Croc Joined: 22 April 2016 Location: UK Status: Offline Points: 1376 |
Hey Beau,
Have you looked at any online designs or are you wanting to design your own from scratch? Think these were pretty thought of for a free plan 18 not a 15 though.... Its worth ringing around local wood stockists. Someone might hold 18mm birch ply. Where are you based?
Edited by JonB67 - 06 June 2021 at 6:07pm |
Beau23
yo I'm beau
I'm 17 and I'm new on this website, to speaker building and the whole forum thing (after posting on several random forums hopefully I've worked out how to do it 😂) so far I've only got sketches and rough idea but would be really good to talk to some people who know what their doing 😂 I was thinking of 2 15" mini scoops (650mm*600mm*800mm)(with 500watt drivers) 2 horizontal mid woofers (still working out a design)(with 300 watt drivers) and a small tweeter (100 watt driver) if anyone can suggest any good designs, driver, places to get 18mm thick ply or can see any obvious mistakes in my plan drop me an email on beausemail23@gmail.com
