Is this a good Acoustical Chart for 18 Tapped Horn |
Augusts ![]() Registered User ![]() ![]() Joined: 07 January 2017 Status: Offline Points: 150 |
![]() ![]() ![]() ![]() ![]() Posted: 27 October 2021 at 3:53pm |
We have been using 18sound 18lw1400 in a cubo sub for years now, it is awesome and its fs ir 31Hz
Here is a graph I did with cubo sub and the RCF , the peaks are only 0,5db higher than the sim with 18sound. Maybe there are other factors? ![]() looks the same as 18sound
snowflake ![]() Old Croc ![]() Joined: 29 December 2004 Location: Bristol Status: Offline Points: 3005 |
no. Fs of that driver is far too low
Hi!
I started my way by using the available plans for Cubo Sub. I was very impressed with the results, with a similar driver as yours also 9mm Xmax. You can find the Cubo Sub hornresp input screen copies online, input those into hornresp and then learn from a readybuilt and tested design. There are many factors you have to take into consideration when starting with hornresp and simulating speakers.
Apex Predator ![]() Registered User ![]() Joined: 11 July 2013 Status: Offline Points: 46 |
Is this a good chart for a 18'' tapped horn. Using an RCF G400. I'm now learning about Hornresp and trying to understand the graphs. Thanks for the help in advance
