Dual 15 + coax |
Post Reply | Page 123 4> |
kipman725
Registered User Joined: 02 September 2020 Location: Warrington Status: Offline Points: 231 |
Posted: 08 August 2022 at 12:04pm |
The 15cl76 looks to be a decent midbass it has 8.5mm xmax, a 3" coil and 0.34 Qes. It also only weighs 3.2kg which is probably important if you're going to put it on a pole.
bob4
Old Croc Joined: 29 February 2004 Location: Finland/Germany Status: Offline Points: 1842 |
15cl76 is a neodymium driver that retails around 175 - 200€ each, so 350 -400€ per box...... not exactly thomann the box budget level? Just wondering........ Nice and interesting project Doober!
Edited by bob4 - 07 August 2022 at 9:34pm |
MarjanM
Old Croc Joined: 10 February 2005 Location: Macedonia Status: Offline Points: 7810 |
Why did you chose that specific 15 inch driver? To me its a shame using top of the line compression driver with a budget 15.
cobrasneverdie
Registered User Joined: 18 July 2022 Status: Offline Points: 16 |
Is there a reason for choosing b&c over bms for crossing that low? My bms 4592nd loads incredibly well all the way down to the horn cutoff on a massive 225hz multicell.
doober
Young Croc Joined: 03 January 2006 Location: Cornwall UK Status: Offline Points: 1118 |
They are finished. I've been using them since December for live music, 2-400 capacity events indoors and outdoors. I like them. The midrange is very clear, the boxes are light enough to get up above head height on a pole. The coax drivers are very efficient, and could easily keep up with way more than the 15s I am using. I do like headroom in the mid and high though. The 2 boxes work well with 4-8 punishers, crossing over around 90Hz. If I used some upper bass boxes between them and took the crossover up to around 180Hz I could get a lot more out of the 15s. |
Blahblahblah
Teunos
Old Croc Joined: 23 November 2008 Location: The Netherlands Status: Offline Points: 1799 |
Hello Doober,
Did you finish these boxes by now? I'm very curious to the results of this design
Best regards,
Teun. |
doober
More progress. I now have 2 boxes. Both have had 2 coats of paint sprayed on and are awaiting a gentle sand and 2 thick coats of paint. I did a test with pole mounting an empty box
The pole is a K&M adjustable with an M20 screw on the base and the expanding ring lock on the top. There is a bit of sway at full extension, but that is to be expected. A single punisher as a base gets the top box just high enough, I will always be using at least 2 though. I didn't like the idea of a surface mounted pole socket, so I knocked this up out of 3mm steel It has an M20 nut welded inside, and fixes with 6 bolts into the horn/driver chamber and 2 through to the exterior with a plate on the outside to spread the load. I had hoped to have the boxes finished ready to use for a couple of gigs next weekend. Unfortunately I can't get another DCX464 driver in time, there doesn't appear to be any stock in the UK. |
Blahblahblah
Keen
Young Croc Joined: 30 May 2011 Location: Brisbane, Aus Status: Offline Points: 1203 |
great to see they made that horn, thanks for sharing
jazomir
Old Croc Joined: 20 November 2006 Location: Sunderland UK Status: Offline Points: 1710 |
Still, nicely done and not too dissimilar to the JTR 215RT speakers with the co-axial HF driver.
toastyghost
The 10,000 Points Club Joined: 09 January 2007 Location: Manchester Status: Offline Points: 10920 |
It’s probably more to do with using a bloody massive horn that was explicitly designed around the (very good) driver attached to the end of it, by proper engineers using top-tier tools such as FEA-based optimisation
jazomir
Slightly off topic, but I came across this the other day - Bennett Prescott sales manager of B&C with a new 2x15 + horn design. Bit (?!) big for pole mounting but sounds very good via utoob - amazing that that it doesn't have any noticeable horn sound on vocals possibly like the Celestion aperiodic driver that removes any crossover artifacts in most of the vocal range.
doober
This was supposed to be a quick project, but then I had a really busy summer and no spare time.... back on it now though.
I put the drivers in for a test A quick outdoor measurement A quite worrying dip around 500Hz. I tried moving the mic around, disconnecting one driver, adding and taking bits of box, and then realised the obvious point that a half wavelength of 500Hz is pretty much the diameter of a 15" driver, which I was listening to from the edge. I modified the baffles and moved some bits in the box Another measurement That's reduced the problem. I need to do more measurements when the weather is good enough, but I think it looks promising. I did a measurement of the mid section I'm thinking a 24dB/octave high pass with the -6dB around 600Hz should be okay. |
Blahblahblah
