Void DSPControl |
Requiem ![]() Old Croc ![]() ![]() Joined: 20 January 2011 Location: Bristol Status: Offline Points: 1787 |
![]() ![]() ![]() ![]() ![]() Posted: 05 August 2021 at 9:22pm |
Theres several intsall files still available on the Void website under legacy stuff, but I had the same problem no matter which one I used.
www.requiem-soundsystem.com
Custom Martin Audio WSX, USB & CSG Soundsystem based in Bristol |
Is this for the void digidrive v2?
I had the same issue with windows 10. I messed about with it for months trying to get it to work. Basically, the windows 10 software is too advanced and you need an older device. I think my friend got it to work with Linux if I remember right? Might be worth finding an old laptop or getting a device solely for the purpose of running this DSP and installing an older version of windows on it like Windows XP |
ashleycornfield ![]() New Member ![]() Joined: 14 March 2021 Status: Offline Points: 5 |
Hi All,
I don't suppose anyone has an install file for the Void DSPControl software? I do have one but i'm getting "DSP Control setup Wizard ended prematurely because of an error" message when trying to install on windows 10. Am I just trying to resurrect a beast that won't go?? thanks in advance
