G3/PSM power distro |
jacethebase ![]() Old Croc ![]() ![]() Joined: 23 September 2009 Location: Somerset Status: Offline Points: 5643 |
![]() ![]() ![]() ![]() ![]() Posted: 07 December 2021 at 10:00pm |
I might have just the things!!!
Drop me a WhatsApp tomorrow and I’ll send you some pics Jace 07766140461
www.stage2sound.com |
BJtheDJ ![]() Young Croc ![]() ![]() Joined: 28 November 2012 Location: Bristol Status: Offline Points: 834 |
The OP is in the UK, and regretfully the conrad.be site appears only to support customers in the EU. or similar would most likely do the job.
then you know that you're not a Millenial kid.</f |
Peter Jan ![]() Young Croc ![]() ![]() Joined: 16 December 2008 Location: Belgium Status: Offline Points: 1007 |
I always use these kind of power supplies to power several Sennheiser/Shure receivers/IEM transmitters in a rack:
https://www.conrad.be/p/mean-well-lrs-75-12-acdc-inbouwnetvoeding-gesloten-6-a-72-w-12-vdc-1439450 Or the ones you can click on a DIN rail : https://www.conrad.be/p/mean-well-dr-120-12-din-rail-netvoeding-12-vdc-10-a-120-w-1-x-1297347?WT.srch=1&gclid=EAIaIQobChMI3Z7LiPbP9AIVBoXVCh2ZrQTkEAYYByABEgJY-vD_BwE&gclsrc=aw.ds&insert=8J&t=1&tid=13894944235_122657379817_pla-301443522443_pla-1297347&utm_campaign=shopping-feed&utm_content=free-google-shopping-clicks&utm_medium=surfaces&utm_source=google&utm_term=1297347&vat=true Way more reliable (never had one go bad in over 20 years of use) than the rubbish original adapters, that have the habit of going bad regularly. Edited by Peter Jan - 06 December 2021 at 7:52pm |
imageoven ![]() Old Croc ![]() Joined: 28 March 2007 Location: Scotland Status: Offline Points: 2133 |
Are these radio mic receivers? Are you looking for a low voltage supply with multiple outlets?
MARTYNJONHALL ![]() Registered User ![]() Joined: 02 January 2005 Location: Burton On Trent Status: Offline Points: 326 |
I've got 4 g3 packs and 4 psm packs in a shallow rack and as you would guess it's like a rats nest in the back.
Is there any way to get a little power splitter for each set of 4 to clear all the psu's out of the way and just have 1 or 2 plugs dropping out of the back instead of 8! Cheers guys Martyn
Edited by MARTYNJONHALL - 06 December 2021 at 2:48pm |
