Thomann T-amp experiences please |
teeth
Young Croc Joined: 05 July 2021 Status: Offline Points: 566 |
Posted: 10 February 2022 at 9:52am |
i have 2 of the 4 channel TSA4 units they are class, i will definitely be owning T-Amp stuff in one way or another for many years to come
slaz
Old Croc Joined: 27 November 2009 Location: London E2 Status: Offline Points: 2713 |
Thanks guys .... I'm convinced enough - I just hit the buy button :-) |
njw
Old Croc Joined: 26 March 2010 Location: S. Wales Status: Offline Points: 2574 |
To answer your question, yes! I had an e800 for a few years, it was used to power mids, tops, dj monitors (usually without a limiter!) and occasionally full range FOH on smaller jobs.The build quality is good with a very solid case and I can't say I noticed any difference in sound quality between it and more expensive amps, oh, and the weight is because it has a whopping great toroid in it! I never used my one exclusively on bass but I wouldn't doubt for a second that it has the power to drive a single bass bin in bridge mode, I'd say the published specs are erring on the low side compared to what it actually puts out. I wouldn't hesitate to buy another.
markie
Old Croc Joined: 31 October 2005 Location: Sunny Liskeard. Status: Offline Points: 4570 |
I had one for a short while. A mate was short of money and sold it to me. He'd had it for quite a while and said it was fine and had no problems with it.
I gave it an extensive test and was quite impressed with it. I only sold it on because I had so many amps at the time. If I needed an amp of that power I would certainly buy another. As you correctly state, 3 year guarantee, can't go wrong.
JBK
Registered User Joined: 03 March 2016 Location: Besançon Status: Offline Points: 262 |
I never used one personally, but I know a reggae sound that use a pile of them (like 4-6 of them) for top end (horns / super tweeter) and play the whole night well into clip. I wouldn't advise doing so of course but that seems to indicate for some reliability. With that in mind and the price and 3years guarantee you can't really go wrong I think.
slaz
Hi y'all .... Wondering if anyone has direct experience of the Thomann t-amp E800 machine ? Claims 2 x 500W > 4R, 2 x 350W > 8R, and 1 x 1kW > 8R bridge. Looks heavy at nearly 13Kg - so surely it must be a linear PSU with toroid. My gut instinct (and I could well be wrong of course) is that tranformer PSUs tend to be more reliable than SMPS (well - unless you're paying top dollar for the likes of Powersoft et al). Nice and simple methinks - no frills. The context is :- 3 possible modes of use :- 1) to run my 2 much beloved FBT Maxx 4 passive mid-tops (4R version). Plenty of headroom there. 2) to run a single Tannoy 15" bandpass sub in 8R bridge. The sub is labelled as 300W - 700W amps recommended. So should be ample headroom also .... and no I'm not expecting full beans at 20Hz - 20KHz both channels driven etc. 3) Might be used to drive 1 FBT mid-top + the 15" sub (1 per channel obviously) ... in this case the sub would be nominally underpowered, but I'm kind of assuming the bandpass sub would have an extra bit of efficiency to compensate. Its only really a hobbyist setup .... occasional use - ONLY EVER controlled by me - and I'm a fairly cautious bod with (I think) enough understanding to not rag it/clip it. So question really is just :- Is this a reasonable quality, competent amplifier ? I certainly like the 3 year warranty ! TIA. |
