Crest CA6 bridged output |
Post Reply | Page 12> |
Author | |||
Old Croc Joined: 02 April 2004 Location: United States Status: Offline Points: 5175 |
Posted: 10 March 2022 at 3:21pm |
One of the reasons I said single socket. The QSC EX 4000 offers three Speakon sockets like the Crest CA 6. Both follow the same wiring configuration upon reading the CA 6 Manual. QSC was the first USA Amplifier manufacture to adapt Speakon on their top of the line series (EX) around 1987. That series was aimed directly to compete against Crown's Macro-tech Series which, dominated the USA touring market in the 1980's. The amount of money Crown made from the Macro-tech 2400... Ridiculous. Best Regards,
Edited by Elliot Thompson - 10 March 2022 at 3:28pm |
4D
Old Croc Joined: 13 November 2008 Location: Winchester Status: Offline Points: 4257 |
EX4000 Methinks you will find the channel a & b outputs are each 1+/1- whereas single speakon socket use's 1+ & 2+ in bridge mode AND 1+/1- & 2+/2- when in in two channel mode As for the OP I would suggest unless your cable runs are over 25m then a single run of 4mm then link the cabs rather than 2 runs of 2 x 2.5mm Edited by 4D - 10 March 2022 at 1:53pm |
Conanski
Old Croc Joined: 26 January 2006 Location: Ottawa, Canada Status: Offline Points: 2537 |
I think I see your point now, they put a dedicated Bridged connector on the thing and could have wired it any way they wanted, but instead of doing it it so a standard straight thru Speakon cable can be used they force you to build a custom.. which is pretty dumb.. completely defeats the point of having a dedicated connector. I would be possible to wire the bridged output to both pairs on the NL4 too, but that would be asking too much I bet.
On my Yamaha amps both outputs appear on Ch1 speakon so a custom cable would be required to access bridged output, but I built a patch panel for the amp rack with connectors prewired to address this so I don't need a special cable or an adapter.
Edited by Conanski - 09 March 2022 at 11:58pm |
Lucasdude
Young Croc Joined: 16 March 2013 Location: London Status: Offline Points: 824 |
It's a fair point, Elliot. Actually, the board still has the binding post holes and traces and the back panel has the 4 holes in it. They are just covered over by the EU version sticker, so it would be fairly easy to add binding posts in addition to the Speakon sockets. I would have to do 4 amps for my project though...
There is no reason why you cannot customize such a tool using one Speakon connector on one end and a Binding Posts on the other end. Customization is very common with sound systems that are not catering to the corporate market.
Best Regards,
Lucasdude
Thanks for your replies. My point is pretty simple. On the binding post version of Crest amps, of which I have had many in the past, I was able to run a pair of cables from ch1 hot and channel 2 hot in bridged mode using spades, and on the Speakon version i cannot.
In Bridged Mode, you use the positive terminal of each channel to connect to the loudspeaker. You never use the negative terminals in Bridged Mode.
Bear in mind, Crest CA Series is exported using Speakon sockets due to Banana Plugs being banned in Europe on power amplifiers delivering a certain amount of power. In the Americas, it is rare to find a Crest CA 6 offering Speakon outputs as, they are equipped to use Banana Plugs.
It is always best to read the manual before posing a question as it will save you a lot of time in finding answers. Especially when you are working with equipment that is obsolete.
Best Regards, Edited by Elliot Thompson - 09 March 2022 at 2:45pm |
Conanski
I think you are missing an important point, bridging a 2 channel amp turns it into a single channel amplifier, bridged power is only available across the combined voltage swing of both channels. You can't get the bridged power from all terminals. Another point I didn't mention earlier, there is only 1200w of output here to be shared by two subs, there really is no need for dedicated cables to each box IMO.
Edited by Conanski - 09 March 2022 at 2:31pm |
Lucasdude
I think its a bit odd that provision is made for all 4 pins in stereo mode, but not in bridge mode. I didn't initially check the manual, I just assumed that the bridge out would be on pins 1+/-. I will need to have dedicated cables for bridge mode on 1+/2+. As all 4 pins are soldered on the board behind the socket, is seems silly not to be able to use them.
Boxes such as the EAW SB 850 were wired in the same manner. It allow each driver to have it's own dedicated amplifier. Great for the touring market however, not ideal for those that must load four loudspeakers (each loudspeaker residing in its own enclosure) on each channel of the amplifier. Hence, the reason to offer three Speakon sockets. This allowed more flexibility based on the user's requirements.
Best Regards, Edited by Elliot Thompson - 09 March 2022 at 10:16am |
Conanski
Ok that make more sense, makes it possible to use a single 4-core cable to biamp a box without any custom adapters.
If it follows the same principal as the QSC EX 4000; Single Speakon Socket Stereo Mode 1+ Positive Left Channel 1 - Negative Left Channel 2+ Positive Right Channel 2 - Negative Right Channel Single Speakon Socket Bridged Mono 1+ Positive Left Channel 2+ Positive Right Channel Best Regards,
