who makes amps for RCF boxes - is it Powersoft ? |
Author | ||
Earplug ![]() Old Croc ![]() Joined: 03 January 2012 Location: Europe Status: Offline Points: 6802 |
![]() ![]() ![]() ![]() ![]() Posted: 14 April 2022 at 9:18pm |
Definitely this. Diagnostics on a high density board is a lot more difficult & time consuming. And try source some of the custom transformers that a lot use. Not easy. |
kedwardsleisure ![]() Old Croc ![]() Joined: 20 January 2009 Location: Staffordshire Status: Offline Points: 4696 |
I've got a plate amp from a JBL PRX just come in last night, together with another from a QSC k-series. I'll let you know which one wins on repairability!
North Staffordshire |
APW ![]() Young Croc ![]() ![]() Joined: 13 November 2012 Location: Kent, UK Status: Offline Points: 1107 |
Yep, amazing consistency and under normal use they would have probably never fail but running 24/7 for several years sent them over the edge. With regarding the replacement driver, It was a long time ago, the shop has been closed for over 10 years, the woofer had a slightly larger than normal (for the time) 12" chassis, and the only drivers what would fit were other RCF drivers that due to the RCF/Mackie fallout were not available, We considered getting adapters machined up but the client didn't like the price. Ironically about a month after they were replaced, RCF sorted out its service network and the re-cone kits became available again. Edited by APW - 14 April 2022 at 5:03pm |
snowflake ![]() Old Croc ![]() Joined: 29 December 2004 Location: Bristol Status: Offline Points: 2921 |
although these resistors were undersized and therefore failed, it is a testament to their consistency and qc that they all failed within weeks of each other ![]() |
cravings ![]() Old Croc ![]() ![]() Joined: 30 January 2007 Location: Ireland Status: Offline Points: 7306 |
I've stuck cheap p-audio 12s into art 312s and they've fitted ok. Just saying.
jammin75 ![]() Old Croc ![]() ![]() Joined: 08 July 2012 Location: west midlands Status: Offline Points: 2315 |
i have a db es 1002 which i use for small tite space gigs can the amp module be repaired ?
feel the vibes !!! "Who Feels it Knows it" Strong like Lion
jbl_man ![]() Moderator Group ![]() Joined: 12 January 2005 Location: London. Status: Offline Points: 11024 |
Anything is repairable if money is no object, but finding someone willing to put the time into repairing, and obtaining certain hybrid parts at an economic rate versus replacement of a module is the question. |
SMD is repairable but can be a PITA compared to thru-hole. Most industrial (and well designed) electronics tends to be a hybrid, with all the small signal components in SMD and the power stuff still thru-hole. Edited by APW - 14 April 2022 at 11:19am |
Line Array ![]() Registered User ![]() Joined: 19 March 2022 Location: New Jersey, USA Status: Offline Points: 78 |
are you guys saying that surface mount devices are not repairable ?
wouldn't that apply to powersoft and other high-density amps as well then ? or basically all modern class D amps ? even my 20 year old QSC PLX ( class H ) is Surface Mount. wouldn't you have to go all the way back to toroid amps under that definition of repairability ? or are you talking about something else ? |
best place on the internet >>>
https://dissidentsound.discoursehosting.net |
An anecdote regarding the old RCF/Mackie Art 300/500
amplifiers, I used to do the electronics repairs for a couple of music shops, one
shop had a service contract at a hotel that had 20 of the Art 300A speakers permanently
installed (at height) in a largish ball room, these were powered 24/7 and the
system worked well for several years, then one weekend 5 died, then a few days
later another 3 failed. The fault was simple in that the amplifier has two 100ohm 1.6watt resistors that drop the +/- 40v rails down to feed the +/-15v rail regulators, one of these resistors would fail and so one of the 15v rails would disappear. This caused both the LF and HF amplifiers to swing hard one way, blowing the output transistors and both the drivers. I advised the shop to get the remaining 12 cabinets to me ASAP
so I could change the 100r resistors so the remaining cabinets wouldn’t suffer
the same fate. The hotel refused to let the shop remove the remaining cabinets as
they were "setting up for a conference and needed them”!! On the day of the conference the shop "got the call" as the rest of the PA had stopped working and could they do something to help!! This all happened at the time when RCF and Mackie were going through their “divorce” and due to the way they had set up the service arrangements the 12” woofer (or re-cone kit) was unobtainable, and as it’s not a standard chassis size nothing else fits the plastic cab. It was decided to wright-off all 20 failed cabinets. …. All because a slightly undersized pair of resistors (and a client that didn't take advice)!! Edited by APW - 14 April 2022 at 10:59am |
"Maybe I'm alone here but I think the 'designed by crown' EON and PRX amps are more friendly to work on." Aye, marginal - but give me an old G2 module any day! ![]() |
The old ART300/500 amps were analogue and thru-hole construction, generally reliable except for the usual problem with most active cabs involving stuff vibrating off the board. SAme with the early DB opera range. But like with anything, cost cutting comes along and the AEB digipro modules are not IMHO really in the same league.
Maybe I'm alone here but I think the 'designed by crown' EON and PRX amps are more friendly to work on. Certainly they have gone to the trouble of writing a service manual with reliability bulletins and diagams in there, which is more than you can say for AEB Industriale who (according to their service agent) want the whole module changing for new. Edited by kedwardsleisure - 14 April 2022 at 9:25am |
