  New Posts New Posts RSS Feed - Powercon 32A usage
Powercon 32A usage
Boxes-R-Blue View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Boxes-R-Blue Quote  Post ReplyReply Direct Link To This Post Topic: Powercon 32A usage
    Posted: 29 May 2022 at 2:04am
"Am I correct that the usage of the 32A version is that the NAC3FC-HC is fitted to an amplifier captive power lead and the NAC3MP-HC the power distro?"
ERR NO!!!!!!!
MP = Male panel IE drain
FC = Female cable IE Source
FFS!
Kinda Been there, Kinda done that, YOU COULDN'T handle my bar bill!
Post Options Post Options   Thanks (0) Thanks(0)   Quote toastyghost Quote  Post ReplyReply Direct Link To This Post Posted: 26 April 2022 at 9:24am
The AMP CPC range handles up to 45A, if you can stomach the cost of the crimp tool.
https://www.te.com/usa-en/plp/connectors-cpc/Y30DqX27y7.html
It's what was used for the Powersoft K20. Might as well go the whole hog with the cloning
Your other option is to look at the chunkier Phoenix options, but they're more for a fixed panel mount than a connector you hot plug.
Edited by toastyghost - 26 April 2022 at 9:25am
kipman725 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kipman725 Quote  Post ReplyReply Direct Link To This Post Posted: 25 April 2022 at 4:08pm
which would be rather dangerous if it was the other way round.
I was looking for a smaller power outlet connector than 32A Ceeform for this amp (K21x4):
DMorison View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMorison Quote  Post ReplyReply Direct Link To This Post Posted: 25 April 2022 at 3:58pm
Well, the "power in" description implies it is used on the amp, not the distro. The cable would then need to be made up with standard 32A Cee @ the distro end and the NAC3FC-HC at the amp end.
The UL certificate also refers to the NAC3MP-HC as an "inlet", not an outlet.
Post Options Post Options   Thanks (0) Thanks(0)   Quote kipman725 Quote  Post ReplyReply Direct Link To This Post Posted: 25 April 2022 at 3:37pm
Unlike standard powercon the 32A connector is only available as:
"powerCON 32 A chassis connector, power-in"
and not in both source and sink variants.
The Wikipedia article states:
"Neutrik introduced a larger 32 A version of the powerCON. Unlike the 20 A version, the 32 A version comes in only one variant which appears to be intended for use as a source"
This page was generated in 0.126 seconds.
