4x 18" drivers for a pair of 218 |
luton_soundman ![]() Old Croc ![]() ![]() Joined: 03 August 2010 Location: Bedfordshire Status: Offline Points: 4280 |
![]() ![]() ![]() ![]() ![]() Posted: 13 May 2022 at 1:22pm |
Hello i have x4 original Turbomax 1200i on the fane chassis for £800
teeth ![]() Registered User ![]() Joined: 05 July 2021 Status: Offline Points: 118 |
cheers monkeypuzzle, gaps in my knowledge showing here... i believe the cab is modelled on the martin 218, it certainly looks like it. from what i know it's a fairly common design with loads of similar things out there, i thought 218 was a common name for that reflex design so thought it would be enough info! i think martin use b&c 18tbx100 in their 218s so something like that maybe i have 4 x 1220W @ 8 ohm power wise. the amp is a 4ch, but can only do 8ohm bridged to 2 annoyingly.
monkeypuzzle ![]() Young Croc ![]() Joined: 25 January 2005 Status: Offline Points: 821 |
I don't have any 18" drivers but anyone who does may need a bit more info. Is the box reflex? - what volume/tuning, is it horn loaded? - what type/plan? What amp would you be driving them with? - (power available/required). Then you might get some offers.
Hi guys, I'm after 4x drivers for a pair of 218's that I'm getting shortly. Open to any suggestions of something suitable! Thank you.
