Compact Amplifier |
dnbpc ![]() Registered User ![]() ![]() Joined: 18 March 2010 Location: Manchester Status: Offline Points: 360 |
![]() ![]() ![]() ![]() ![]() Posted: 09 November 2022 at 2:07pm |
I'm after a compact amplifier that can fit in one section of an ikea kallax unit (13" maximum width) so its hidden away nicely.
Needs to have a decent bit of power behind it as it's powering a pair 16 ohm volt fr220.1 I've been using a matrix ukp500 while they've been in the basement but needs to look a bit neater now the decks are in the living room. Any suggestions?
Pick & Mix Soundsystem
toastyghost ![]() The 10,000 Points Club ![]() ![]() Joined: 09 January 2007 Location: Manchester Status: Offline Points: 10883 |
Sounds like a Hypex NCore module in a hobby case would be ideal. Shouldn't cost crazy money, either.
Example: https://kjfaudio.com/product/hypex-ncore-nc400-mono-block-amplifier-diy-kit/I Edited by toastyghost - 09 November 2022 at 4:12pm |
Earplug ![]() Old Croc ![]() Joined: 03 January 2012 Location: Europe Status: Offline Points: 7006 |
How DIY do you want to go? I have used these for several projects:- Modern version of the classic Hitachi module from the 80's. Sound good and pretty much bomb-proof, but you will have to build/buy a PSU for the thing. ![]() |
Both look like pretty good projects, I kind of like the idea of the DIY route but I reckon I'll struggle to find the time to actually finish it.
If anyone knows of an off the shelf solution for similar kind of money that's probably the best solution. If not it's time to dig out the soldering iron!
There are quite a few plate amp things out there, easy enough to search. The Hypex modules look good, but are expensive. Finding something affordable - and reliable is the thing. ![]() |
fatfreddiescat ![]() Young Croc ![]() ![]() Joined: 15 October 2010 Location: N.E.Wales Status: Offline Points: 1048 |
Blue Aran's Jam Q3 also available from Soundgear as the Jupiter J4 is made up of 4 sperate amplifier/SMPS units.
service dept Steve ![]() Old Croc ![]() Joined: 30 January 2010 Location: S.W.London Status: Offline Points: 2030 |
Quad 405? That must be that sort of size. 125 (good) watts
We are not "They", We are "The others"http://www.servicedept.co.uk -
The Quad looks like it would do the trick but is 1cm too big
kipman725 ![]() Registered User ![]() Joined: 02 September 2020 Location: Warrington Status: Offline Points: 221 |
extron XPA, often available cheap on ebay: https://www.extron.com/product/xpau3502
APC321 ![]() Young Croc ![]() Joined: 24 August 2013 Location: West Midlands Status: Offline Points: 608 |
Shame about the Quad 405 being just too big.
The Quad 405's replacement the Quad 606 will just fit. But they are expensive. The 405 looks good value for money secondhand, and is beautifully made. Several for sale on ebay btween £250 to £300. Maybe time to buy a new shelving unit. |
Meat Substitute ![]() Registered User ![]() ![]() Joined: 10 July 2020 Status: Offline Points: 58 |
I think the size of the Matrix you've been using is about right. I used to use the newer 1u Matrix for mine and that was good. Is there a Lab Gruppen Lucia in the right power range? They have quite a lot of options. I bought one myself SH but it was DOA and had to go all buyer protection on it so never got to try it.
fat_brstd ![]() Old Croc ![]() Joined: 23 August 2008 Location: Melbourne, OZ Status: Online Points: 2098 |
QSC SPA2-200? Not sure how it would go driving a 16ohm but great little install amp, passive cooling and can be hidden just about anywhere.
Melbournes Rootical Warrior Roots - Dub - Steppers facebook page |
