Rj45 in a xlr type body. |
kevin tyler ![]() Old Croc ![]() Joined: 15 April 2007 Location: Spain Status: Offline Points: 3394 |
![]() ![]() ![]() ![]() ![]() Posted: 03 December 2022 at 3:23pm |
Hi guys
Hope all are well, when you mount an existing lan cable in one of these plugs, do you have to snip the latch off the plug ? Many thanks Kev |
toastyghost ![]() The 10,000 Points Club ![]() ![]() Joined: 09 January 2007 Location: Manchester Status: Offline Points: 10889 |
No, there’s a cutout for it that you can see in the photos there.
The connection should still latch. The relevant EtherCon socket on the other end should release the latching tab on the RJ45 connector when the push tab on the socket is pressed. If you’re making a new cable and termination to go in the EtherCon connector, then it’s good practice to tie the drain of the CAT cable to the outer ring of the EtherCon. That should ensure a shielded connection; commonly mixing desks such as the Behringer X32 won’t have a shielded connection to their digital stage boxes if this isn’t done. Edited by toastyghost - 03 December 2022 at 4:37pm |
BJtheDJ ![]() Young Croc ![]() ![]() Joined: 28 November 2012 Location: Bristol Status: Offline Points: 868 |
Same Page but in English
then you know that you're not a Millenial kid.</f |
Thanks toasty ghost, it’s only the lan cable from my router to the berry x air,
Cheers.
