Compression drivers/tweeters |
ceharden ![]() The 10,000 Points Club ![]() ![]() Joined: 05 June 2005 Location: Southampton Status: Offline Points: 11696 |
![]() ![]() ![]() ![]() ![]() Posted: 31 December 2022 at 12:47am |
If you're just running a single compression driver then there's no big difference between 8R and 16R drivers, except that the higher impedance driver will require a higher Voltage from the amplifier for the same power.
When looking at a system as a whole, there are various reasons why a designer might choose to use 16R drivers. If a cab contains multiple compression drivers (such as a line array) then two drivers can be paralleled but still present an 8R load for a single cabinet. In the case of a 2 or 3-way cab containing a passive crossover and where the HF needs to be attenuated (as is normally the case), a 16R HF driver may reduce the power needing to be dissipated in an L-Pad for example because the driver will naturally draw less power for the same Voltage input. |
dj jammin ![]() Young Croc ![]() ![]() Joined: 10 April 2010 Location: southampton Status: Offline Points: 762 |
Question: is there any reason to favor 16ohm compression drivers over 8ohms? If the comps are active crossed and have their own amp channel the only potential advantage I can see is being able to power more comps per amp channel.. correct me if I'm wrong..
Also, I've always thought it's best with compression drivers/tweets to not run at low impedance/too many drivers on one amp channel, i try to keep to one 8ohm driver per amp channel if poss or 2 8ohm drivers per channel at a push.. my question is: could there be any issue running say 4 16ohm drivers or 2 8ohm drivers from an amp channel for hf? Is there really any advantage running hf amp channels at say 8ohms max?
Reverence Sound system
