X1’s with DM2 |
Andrew ![]() Registered User ![]() Joined: 10 March 2004 Location: United Kingdom Status: Offline Points: 669 |
![]() ![]() ![]() ![]() ![]() Posted: 11 December 2004 at 11:38am |
If you've a tail lift and a gang to move things, go for the big lumpy stuff, it's much quicker and easier, particularly if you use the same configuration each time.
whitehousejamie ![]() Young Croc ![]() Joined: 08 March 2004 Location: United Kingdom Status: Offline Points: 1485 |
Personally, i wouldn't go for the DM2, its too heavy. I personally would go for stacks of X1, HD15 and X15.
Hobbyist2004 ![]() Registered User ![]() Joined: 06 July 2004 Status: Offline Points: 99 |
Hi, My original plan was to use my 2 - X1's stacked with an X12 on top. But now looking at the DM2, it seems like it would be nicer than the X12, not to mention it is almost the same width/height as the X1. This would keep things looking symetrical. What are the advantages of going with the DM2 instead of the X12, would I still need the HD15 to add punch around 80-150hz if I used the DM2. Thanks
