  New Posts New Posts RSS Feed - bootleg astera
bootleg astera
monkeypuzzle View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote monkeypuzzle Quote  Post ReplyReply Direct Link To This Post Topic: bootleg astera
    Posted: 08 January 2023 at 10:09pm
The most important difference I’ve found with generic Chinese is build quality. An amp in a rack should last reasonable well but a light with a poorly built yoke or other parts deteriorate pretty quickly as they are moved from gig to gig and just aren’t worth repairing. A company in know have over 500 high power ip65 RGBW LED floods in stock and whilst they are great (I bought 8 from them) their pile of broken ones is rapidly growing and the faults are numerous from colours flickering, dead cells, dead units dead displays. The list is as long as there are components in the units. At 250 dollars a unit plus what ever you can get a shipping container for at the time I doubt many will be fixed. Branded stuff would just have a few common problems that affect units as they age that are widely recognised and solutions are usually found to deal with them.
Edited by monkeypuzzle - 08 January 2023 at 10:40pm
csg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote csg Quote  Post ReplyReply Direct Link To This Post Posted: 08 January 2023 at 9:57pm
If they are asking you for Astera, they want Astera, not a copy.
For your use, its a completely different question
The way Chinese manufacture is arranged there are thousands of small assemblers making product from parts made by larger manufacturers. The difference between QC standards and the give a f**k quotient varies dramatically and basically its a complete crap shoot without prior knowledge.
Im not sure I would agree that all Chinese clone amps have been fantastic. Quite the opposite infact i think
Edited by csg - 08 January 2023 at 9:58pm
teeth View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote teeth Quote  Post ReplyReply Direct Link To This Post Posted: 08 January 2023 at 8:38pm
i wonder if punters could tell they are the real thing or not though ;)
yeah, all good points csg.
i'm only considering it as the chinese clone amps have all been fantastic from what i've seen.
wondering if they are basically identical to the real thing.
hard to tell though... and like you say, could be a gamble
csg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote csg Quote  Post ReplyReply Direct Link To This Post Posted: 08 January 2023 at 5:18pm
They are probably quite usable, most led from china is
However…..
People hiring usually want the real thing
Any serious faults and its usually skip time, environmental carcrash
Any dangerous faults ( I’ve witnessed Chinese beam 200’s in flames and I’ve serviced similar units with curious errors like the lamp blower fitted and working correctly bolted against a solid piece of metal, so it couldn’t move any air….) will be your liability if you can be proven to be using equipment without the correct safety approvals such as TUV/CE/BS
You certainly can get good kit from China, ive done it, but i have to do extensive QC, and lots of involved checking on any safety approvals that i am presented with, and most are false, and ive only purchased Chinese equipment when it has been for wet hire use, for dry hires it simply doesn’t make sense
Post Options Post Options   Thanks (0) Thanks(0)   Quote teeth Quote  Post ReplyReply Direct Link To This Post Posted: 08 January 2023 at 2:33pm
considering getting some tbh, aliexpress has them for £250 a pop.
i'm intrigued, they are just leds and housing. could be some good $ to be made on hires...
This page was generated in 0.066 seconds.
